So the Bird is still not running right.
I have a theory, but Im not sure if Im on the right track.
It will build 10PSI when revving ONCE in neutral. It shouldnt build but mabey 1 psi TOPS.
With the boost referance hooked directly to the wastegate, I can make 19 PSI while driving. The wategate is factory set to 10Lbs, factory. I can put 10 PSI directly to the wastegate line, and it moves (opens at around 10 PSI.
Its low on power almost until I hit that 19psi mark, and then it takes off with decent power. It doesnt steadily build power as teh boost goes up, its one big jump.
My air meter door flapps while cruising at normal Hwy speeds after a few seconds of cruising steady.....it starts flapping a tiny bit, and builds to the point of bucking the car around (changing the af ratio) and you have to downshift and build revvs a bit to keep it going.
HORRIBLE gas milage. I used to get 28 or so MPG on the highway, without beating on it wih very similar mods. Now i get 16.5 TOPS.
NOW, I was told by the previous owner years ago that they gutted the cat out. I think he lied to me. I looked at the DP/Cat assy, and there are no marks or other evidence of it being cut apart or gutted at any point. If the cat is plugged pretty good (if its still there) (after running race gas, running rich ect) could THAT be the cause of all my issues? I'm really greasping at straws here, but it seems to explain all my issues that Im seeing. Also, the car doesnt seem that loud, even with it straight piped without a muffler!
What do you guys think? Does anybody have any time available that I could get the ccar out to you, remove the DP/cat assy (4 bolts total) and gut the cat out? I guess it would be worth a try at this point!
