| Blinkers Not Working, WTF | |
| Subject: Blinkers Not Working, WTF Thu Oct 14, 2010 11:19 pm | |
| Less than 48 hours from track day at Byron and what do you know, my car has a problem, neither blinker has worked as of first start up today. I havent investigated at all but im hoping its just the flasher, again (replaced 9/2/2010). If anyone has any other ideas please chime in. Car is a 1994 Trans Am btw | |
| Subject: Re: Blinkers Not Working, WTF Thu Oct 14, 2010 11:21 pm | |
| If it isn't a flasher. Check tail light ground. Usually only affects one side or the other | |
| Subject: Re: Blinkers Not Working, WTF Thu Oct 14, 2010 11:22 pm | |
| does anything else not work thats also located on the multifunction switch? | |
| Subject: Re: Blinkers Not Working, WTF Thu Oct 14, 2010 11:26 pm | |
| My wipers and that all work on the switch. both blinkers are no go but i will check the grounds tommorrow. | |
| Subject: Re: Blinkers Not Working, WTF Thu Oct 14, 2010 11:28 pm | |
| I doubt the grounds are bad on both sides... If you replaced the flasher once before Id start there. | |
| Subject: Re: Blinkers Not Working, WTF Thu Oct 14, 2010 11:32 pm | |
| Probably not. Looks like ill just have to swing by autozone on my way to work and get another flasher | |
| Subject: Re: Blinkers Not Working, WTF Fri Oct 15, 2010 2:00 am | |
| Do the bulbs light up just not flash? |
| Subject: Re: Blinkers Not Working, WTF Fri Oct 15, 2010 8:15 am | |
| you dont NEED blinkers.........just use arm signals | |
| Subject: Re: Blinkers Not Working, WTF Fri Oct 15, 2010 9:54 am | |
| - bigbird94 wrote:
- Probably not. Looks like ill just have to swing by autozone on my way to work and get another flasher
That could be your problem right there. Go to the dealer and get yourself a genuine AC Delco flasher. It will cost you a few bucks more, but how many times do you want to do the job? |
| Subject: Re: Blinkers Not Working, WTF Fri Oct 15, 2010 10:19 am | |
| - nightrunner06 wrote:
- you dont NEED blinkers.........just use arm signals
+1 | |
JamesZ28 Legit
Posts : 520 Join date : 2010-04-05 Age : 33 Location : Waupun, WI
| Subject: Re: Blinkers Not Working, WTF Fri Oct 15, 2010 11:31 am | |
| dumbass, you didn't even check the blinker fluid did you?! | |
| Subject: Re: Blinkers Not Working, WTF Fri Oct 15, 2010 11:40 am | |
| ^ I run synthetic blinker fluid so that cant be the problem. moparkid is probably right on the money. My hazards arent working either..and the flasher controls those too | |
| Subject: Re: Blinkers Not Working, WTF Fri Oct 15, 2010 7:12 pm | |
| well I was going to ask you if your hazard switch is working right most signals inop I see are from a bad hazard switch. now yours is the old school style but they are also known to get dirty inside the column and cause issues just like the old smoking column the old cars had when the signal is on coming off the hwy |
| Subject: Re: Blinkers Not Working, WTF Sun Oct 17, 2010 2:01 pm | |
| I put in a new flasher firday night and problem solved. thanks for all the input everyone | |
| Subject: Re: Blinkers Not Working, WTF Sun Oct 17, 2010 3:00 pm | |
| &^^^^^^ didnt see you at byron???? | |
| Subject: Re: Blinkers Not Working, WTF Sun Oct 17, 2010 3:08 pm | |
| Subject: Re: Blinkers Not Working, WTF Sun Oct 17, 2010 3:45 pm | |
| Im sorry about that guys. My passenger backed out friday afternoon and I couldnt find any one else on such short notice. Byron is like a 3 hour drive from waupun and it would have been really lame driving alone. Plus College Gameday was in Madison so I stuck around. | |
| Subject: Re: Blinkers Not Working, WTF | |
