| 53 Chevy Straight Six Help | |
| Subject: 53 Chevy Straight Six Help Wed Oct 27, 2010 10:35 pm | |
| Subject: Re: 53 Chevy Straight Six Help Wed Oct 27, 2010 10:39 pm | |
| if you havent used any wd40 and tried like hell with a wrench then a powerdrill and new bellhousing would be my plan. | |
| Subject: Re: 53 Chevy Straight Six Help Wed Oct 27, 2010 11:42 pm | |
| The fire wrench is your friend. After you get it good and hot, give the bolts a quick spray with PB blaster, Kroil, or something like it. WD-40 IMHO only displaces water, and isn't a real effective penetrating oil.
Usually you can just soak the bolts with PB blaster and let them sit for a while (overnight works) and you should be able to pop them loose with a bit of heat, even if you can only get an open ended wrench on them. | |
| Subject: Re: 53 Chevy Straight Six Help Thu Oct 28, 2010 2:09 am | |
| X2 on the PB blaster. That stuff is amazing. I use it all the time when restoring old motorcycles. Good luck! | |
| Subject: Re: 53 Chevy Straight Six Help Thu Oct 28, 2010 9:44 am | |
| PB blaster works good, but a 50/50 mix of ATF and acetone works better dude awesome progress! If you need any help let me know. Im more than willing | |
| Subject: Re: 53 Chevy Straight Six Help Sat Oct 30, 2010 8:11 am | |
| thanks for the help guys. i have no torch so heats a problem. haven't had time to try again yet but i soaked it in wd 40 on wed, we'll see what happens tomorrow |
| Subject: Re: 53 Chevy Straight Six Help Sun Oct 31, 2010 12:48 pm | |
| make sure you heat the block/where the bolt is threaded in as opposed to the bolt head. you dont want to expand the bolt, just the block/threads. i just turn that area orange, move over to the other side turn that area orange, repeat three times w/o stopping & theyll come out like they were installed yesterday... | |
| Subject: Re: 53 Chevy Straight Six Help Sun Oct 31, 2010 5:05 pm | |
| well i tried heat yesterday and i still cant get the fuckers, there's just not enough torque with the open end wrench. so idk what i'm thinking about doing now |
| Subject: Re: 53 Chevy Straight Six Help Sun Oct 31, 2010 6:26 pm | |
| why are you taking the engine apart? | |
| Subject: Re: 53 Chevy Straight Six Help Sun Oct 31, 2010 9:53 pm | |
| Old way, a last ditch effort (if you can get a pry bar in there to hold the wrench on the bolt head and pipe over the wrench for you missing torque and they will have to come loose OR BRAKE!
Then drill tap!
TWO PERSON JOB.
good luck |
| Subject: Re: 53 Chevy Straight Six Help Sun Oct 31, 2010 10:12 pm | |
| tim part of the problem is he can only get an open end wrench on it. i think he will round it off first. what about a 0 offset box end? | |
| Subject: Re: 53 Chevy Straight Six Help Sun Oct 31, 2010 10:25 pm | |
| WD40 is not going to help. It is a water displacer. Try an actual penetrating oil. | |
| Subject: Re: 53 Chevy Straight Six Help Sun Oct 31, 2010 10:54 pm | |
| where you got this beast? pm me an maybe we can setup a time to warm that sucker up this week. | |
| Subject: Re: 53 Chevy Straight Six Help Mon Nov 01, 2010 12:42 am | |
| - overblown wrote:
- WD40 is not going to help. It is a water displacer. Try an actual penetrating oil.
Thats what she said |
| Subject: Re: 53 Chevy Straight Six Help Mon Nov 01, 2010 6:58 am | |
- tim part of the problem is he can only get an open end wrench on it. i think he will round it off first. what about a 0 offset box end?
I see that now, well you would thinK if a open fits a offset box will also? There has to be a way. More heat maybe, (but with the limited space i can see that not working so well) |
| Subject: Re: 53 Chevy Straight Six Help Mon Nov 01, 2010 8:56 am | |
| its in my shed in Cross plains. and i'm planning on rebuilding it this winter. Nate i'll PM you when i know what i have going this weekend. Steve sorry for my stupidity but whats a 0 offset box end? never heard of it. my big problem is i can only turn the wrench like 5 degrees, so i don't even know if its rusted on or stuck. |
| Subject: Re: 53 Chevy Straight Six Help Mon Nov 01, 2010 11:26 am | |
| Subject: Re: 53 Chevy Straight Six Help Mon Nov 01, 2010 11:31 am | |
| the block needs to be heated not the bolt. since i have disassembled i dont know how many of those over the years ill show you the way/heat wrench is your friend & i will bring an assortment of sae wrenches...
im planning on going up to my dads shop this week to get my blast cabinet so keep me updated an ill load up the torch. | |
| Subject: Re: 53 Chevy Straight Six Help Mon Nov 01, 2010 4:51 pm | |
| i've borrowed a torch, so i have one here. and i tired heating the block. i'm going to try some more tonight and if i can't get it tonight i'll give you a shout |
| Subject: Re: 53 Chevy Straight Six Help Mon Nov 01, 2010 6:18 pm | |
| normal wrenchs have the box end a slight angle..... the other ones are straight | |
| Subject: Re: 53 Chevy Straight Six Help Tue Nov 02, 2010 8:44 am | |
| thats kinda what i was thinking, but i got the some bitch last night, i ended up grinding down about half of a box wrench and got it in there. thanks for the suggestions and offers of help |
| Subject: Re: 53 Chevy Straight Six Help Tue Nov 02, 2010 6:23 pm | |
| Cool ,good luck on the rest of your project! |
| Subject: Re: 53 Chevy Straight Six Help Tue Nov 02, 2010 9:39 pm | |
| - outlaw1 wrote:
- Cool ,good luck on the rest of your project!
Yeah, keep us updated | |
| Subject: Re: 53 Chevy Straight Six Help | |
