| oily spark plugs? | |
+2Disgustang Fuckin Schiller!! 6 posters |
| Subject: oily spark plugs? Tue Oct 26, 2010 9:28 pm | |
| I changed the spark plugs in my friend's '92 Escort with a DOHC 1.8L and like 115k on it. I also changed the oil/filter because it hadn't been changed in like 8000 miles. when I took out the plugs they were completely covered in oil on the top ends, all 4 of them. I don't know much about this and I've never seen it before. is this normal or a bad thing, and what can be done about it? | |
| Subject: Re: oily spark plugs? Tue Oct 26, 2010 9:37 pm | |
| my guess is bad gaskets around the plug tubes and oil leaks down there when you pull them it covers the plugs in oil. not really a huge deal. | |
Rac3c4r Legit
Posts : 643 Join date : 2010-01-26 Age : 34
| Subject: Re: oily spark plugs? Tue Oct 26, 2010 9:50 pm | |
| My neon had the same issue.. | |
| Subject: Re: oily spark plugs? Tue Oct 26, 2010 10:41 pm | |
| Its just the valve cover gasket! no biggie | |
| Subject: Re: oily spark plugs? Tue Oct 26, 2010 11:01 pm | |
| yeap bad valve cover gasket. I see that all the ime on escorts and focus' at work. Its real easy to do. If you want help let me know, takes like ten minutes | |
| Subject: Re: oily spark plugs? Wed Oct 27, 2010 12:11 am | |
| my SHO had a real bad misfire pulled the plugs, full of oil. just the o ring seals. | |
| Subject: Re: oily spark plugs? Fri Jan 14, 2011 4:53 am | |
| ...what? please go post an intro in the introductions section of the forum. you're not going to get any help if we don't know who you are or what you drive. | |
| Subject: Re: oily spark plugs? Fri Jan 14, 2011 8:06 am | |
| - Fuckin Schiller!! wrote:
- ...what? please go post an intro in the introductions section of the forum. you're not going to get any help if we don't know who you are or what you drive.
I deleted his post since he is just a spammer. |
| Subject: Re: oily spark plugs? Fri Jan 14, 2011 10:02 am | |
| My work car at the time, an Accord, had the same issue. When I had it torn apart for other things, I fixed that issue too. Cam tower seals they are called on a Honduh. Unless it's causing a missfire, I wouldn't worry about it. Look at it this way, the plugs should never seize into the head. |
| Subject: Re: oily spark plugs? Fri Jan 14, 2011 2:49 pm | |
I deleted his post since he is just a spammer. I suspected. just didn't wanna be an asshole and say it since I wasn't sure. | |
| Subject: Re: oily spark plugs? Fri Jan 14, 2011 8:18 pm | |
| did you fix this david? I can tell you its definitley the valve cover gasket on that car if you havnt done it yet. | |
| Subject: Re: oily spark plugs? Fri Jan 14, 2011 9:31 pm | |
| no, I haven't yet. I totally forgot about it lol. | |
| Subject: Re: oily spark plugs? Fri Jan 14, 2011 11:12 pm | |
| On the 1.8 it takes like 10 minutes! hell you can reuse the gasket if it isnt cracked. | |
| Subject: Re: oily spark plugs? Sat Jan 15, 2011 2:29 am | |
| an OEM ford gasket for its not very much though, I could probly get it for under twenty | |
| Subject: Re: oily spark plugs? Sat Jan 15, 2011 4:22 am | |
| alright, I'll talk to her and see if she wants me to do it | |
| Subject: Re: oily spark plugs? | |
