 vinyl clean up
PostSubject: vinyl clean up   Sat Feb 13, 2010 2:29 pm
Hey Detailing guys
I thought I'd get your opinion on this one. I'm removing the old vinyl C strip on the coronet because of a three inch section that tore loose and is gone. Well I'm replacing it with a new sticker, but after I get the old one off. I will need to clean it properly. I';m thinking good old elbow grease with water and soap should work, but I figured I would get some opinions from you guys. Do you gus suggest anything different or something that might work easier to cleaqn it up.
Thanks
Administrator
PostSubject: Re: vinyl clean up   Sat Feb 13, 2010 3:24 pm
The orange Goo B gone shit works really well and it's safe. I used it on my paint where I debadged the trunk and we used it on Tim's paint. It worked good and there was no issue and new adhesive went right back on the same spot with no issue.
http://www.wistreetandtrack.com
PostSubject: Re: vinyl clean up   Sat Feb 13, 2010 4:12 pm
Great! Thanks Peter! I assume i can get that at most automotive or hardware stores then?
Administrator
PostSubject: Re: vinyl clean up   Sat Feb 13, 2010 4:47 pm
Yeah, even Walmart. I've never used it on vinyl but it says it's safe for anything.
PostSubject: Re: vinyl clean up   Sat Feb 13, 2010 4:50 pm
Mikey, 3M makes a product called wax and adhesive remover. You can get it at most parts stores or at Body Shop Supply. From my personal experience, its pretty good stuff. Here's a link to 3M's website: http://www.3m.com/product/information/Adhesive-Wax-Remover.html
You can get it in aerosol form, or liquid form in a squeezeable metal container. Put a little on a rag and the adhesive is gone.
PostSubject: Re: vinyl clean up   Sat Feb 13, 2010 4:58 pm
this is the stuff that the detailing department at the dealer i worked at used.
PostSubject: Re: vinyl clean up   Sat Feb 13, 2010 5:19 pm
Yup, good stuff right there.
PostSubject: Re: vinyl clean up   Sat Feb 13, 2010 5:36 pm
Wow, thanks guys! I apprciate the help. I just got back from the store and bought some Orange Goo B gone. I'm going to lift the sticker and try and clean it up. If it still seems gunky I'll swing by autosupply store on monday and see if I can find some 3m adhesive wax remover.
Again thanks, its nice to see their are other options out there.
PostSubject: Re: vinyl clean up   Sat Feb 13, 2010 6:58 pm
I've used goo gone along with generic bug and tar remover also. You should be fine Wink
vinyl clean up
