| E85 conversion | |
+5Rac3c4r Mr Peepers Mclovin23 2jz-U-Ltr MikeyT 9 posters |
| Subject: E85 conversion Wed Dec 29, 2010 8:50 pm | |
| Ive been toying with the idea of converting to run on E85. From a bit of research it looks like the general recommendation is to increase the injector size, and possibly the fuel pump. My current injectors are 630cc and seem that they would be capable of handling the increased flow rate.
The fuel pump on the other hand may need to be swapped out for a 190 or 255 lph pump. The 190 is good to 350 hp which i will probably never come close to making, yet the 255 is the same price. Any advantage of staying with the smaller fuel pump?
Is there anything else I am missing other than to have it tuned again? |
| Subject: Re: E85 conversion Wed Dec 29, 2010 8:54 pm | |
| I'm guessing you will need to change plugs to something hotter to lite the fuel.
| Subject: Re: E85 conversion Wed Dec 29, 2010 9:12 pm | |
| E85 requires an average of 30% increase of fuel delivery. I have no idea why your injectors are so massive but they will be plenty and then some. I would say go with a 255 because it won't hurt anything but too little sure will. Not sure if you would need a regulator or not. | |
| Subject: Re: E85 conversion Wed Dec 29, 2010 9:45 pm | |
| 630s are not that big especially when running e85 on turbo/supercharged cars. but like peaches said its 30% more fuel. some tune on pump and increase the tables 30% and go from there. maybe try it out but watch your IDC %. fuel pump is always a good inexpensive upgrade to have | |
Mr Peepers Legit
Posts : 235 Join date : 2010-05-31 Location : Janesville
| Subject: Re: E85 conversion Wed Dec 29, 2010 9:53 pm | |
| All depends on how much power you're looking to make. | |
| Subject: Re: E85 conversion Wed Dec 29, 2010 9:57 pm | |
| Im not looking to make alot of power at all. Last time it was dyno'ed it was at 200 hp at 8 psi, now its up around 11-12 psi. I wouldn't be disappointed with a gain in power, but the reason behind this was to do something different. |
Rac3c4r Legit
Posts : 643 Join date : 2010-01-26 Age : 34
| Subject: Re: E85 conversion Wed Dec 29, 2010 10:56 pm | |
| At injector max, and 15 or so psi, i wouldn't be surprised if you made ~265.. | |
Mr Peepers Legit
| Subject: Re: E85 conversion Thu Dec 30, 2010 12:19 am | |
| 630's should be good up to the 300whp mark on e85 so all is fine there. I'm not sure what style fuel system you have(return or pulse) or if the extra flow will cause any problems with overrun but it's really a toss up. If you don't plan on going bigger I don't see a problem with a 190 or maybe even something like a second hand evo8 fuel pump; just make sure your boost+base fuel pressure isn't going to exceed the evo8 pump's relatively low bypass pressure(~65psi). Perhaps just rewire yours? | |
| Subject: Re: E85 conversion Thu Dec 30, 2010 11:12 am | |
| if your leaving your car stock and just want to run e85 im willing to bet your stock ones will be fine with fpr. | |
| Subject: Re: E85 conversion Thu Dec 30, 2010 11:41 am | |
| - mr.johnson wrote:
- if your leaving your car stock and just want to run e85 im willing to bet your stock ones will be fine with fpr.
My car is not stock, but all the engine internals are. Also I believe I am pushing my current stock fuel pump near its limit, so that would definitely be replaced. |
| Subject: Re: E85 conversion Thu Dec 30, 2010 12:40 pm | |
| for a turbo car its a good idea. but my main concern would be your bottom end. how much power can the stock corolla bottom end take? sounds like your injectors would be good and all you would need is the pump and a tune. turn up the boost and timing and have fun. if the bottom end can take the extra power there is no reason you shouldnt do it. | |
JDMasfck Legit
Posts : 964 Join date : 2010-05-13
| Subject: Re: E85 conversion Thu Dec 30, 2010 1:07 pm | |
| ^ this is the import section.. I believe you are in the wrong area.
( but serious...what he said ) | |
spyderToph
Posts : 264 Join date : 2010-02-05
| Subject: Re: E85 conversion Thu Dec 30, 2010 1:11 pm | |
| Stock bottom end will hold about 250-275whp. A bigger pump is a good idea and maybe a lower temp T-stat like TRD or MWR. | |
| Subject: Re: E85 conversion Fri Dec 31, 2010 12:07 pm | |
| Biggest issue is doing something about tuning. You need to be able to adjust the cranking fueling, tip-in, and flow scaling for E85. hotter plugs are not needed. Properly tuned, a close friend runs one step colder plugs on his STI and his car cranks right up at 1F on E85 (winter blend). Also, you need to make sure your stock fuel lines can handle Ethanol. Most cars can handle lower concentrations no problem, but not all cars are the same. Newer Subarus are great to run E85 since people have been running it for close to 5 years with no deterioration or problems. https://www.youtube.com/watch?v=c-RJVqhtXXw |
| Subject: Re: E85 conversion Fri Dec 31, 2010 2:17 pm | |
| most modern cars will have no issues with the ethanol. | |
spyderToph
| Subject: Re: E85 conversion Sun Jan 02, 2011 11:37 pm | |
| Are you running a PowerFC? | |
| Subject: Re: E85 conversion Sun Jan 02, 2011 11:38 pm | |
| Subject: Re: E85 conversion | |
| E85 conversion | |
