 oily spark plugs?
6 posters
oily spark plugs? Empty
PostSubject: oily spark plugs?   oily spark plugs? Icon_minitimeTue Oct 26, 2010 9:28 pm
I changed the spark plugs in my friend's '92 Escort with a DOHC 1.8L and like 115k on it. I also changed the oil/filter because it hadn't been changed in like 8000 miles. when I took out the plugs they were completely covered in oil on the top ends, all 4 of them. I don't know much about this and I've never seen it before. is this normal or a bad thing, and what can be done about it?
PostSubject: Re: oily spark plugs?   oily spark plugs? Icon_minitimeTue Oct 26, 2010 9:37 pm
my guess is bad gaskets around the plug tubes and oil leaks down there when you pull them it covers the plugs in oil. not really a huge deal.
PostSubject: Re: oily spark plugs?   oily spark plugs? Icon_minitimeTue Oct 26, 2010 9:50 pm
My neon had the same issue..
PostSubject: Re: oily spark plugs?   oily spark plugs? Icon_minitimeTue Oct 26, 2010 10:41 pm
Its just the valve cover gasket! no biggie
PostSubject: Re: oily spark plugs?   oily spark plugs? Icon_minitimeTue Oct 26, 2010 11:01 pm
yeap bad valve cover gasket. I see that all the ime on escorts and focus' at work. Its real easy to do. If you want help let me know, takes like ten minutes
PostSubject: Re: oily spark plugs?   oily spark plugs? Icon_minitimeWed Oct 27, 2010 12:11 am
my SHO had a real bad misfire pulled the plugs, full of oil. just the o ring seals.
PostSubject: Re: oily spark plugs?   oily spark plugs? Icon_minitimeFri Jan 14, 2011 4:53 am
...what? please go post an intro in the introductions section of the forum. you're not going to get any help if we don't know who you are or what you drive.
PostSubject: Re: oily spark plugs?   oily spark plugs? Icon_minitimeFri Jan 14, 2011 8:06 am
I deleted his post since he is just a spammer.
PostSubject: Re: oily spark plugs?   oily spark plugs? Icon_minitimeFri Jan 14, 2011 10:02 am
My work car at the time, an Accord, had the same issue. When I had it torn apart for other things, I fixed that issue too. Cam tower seals they are called on a Honduh.
Unless it's causing a missfire, I wouldn't worry about it. Look at it this way, the plugs should never seize into the head. Razz
PostSubject: Re: oily spark plugs?   oily spark plugs? Icon_minitimeFri Jan 14, 2011 2:49 pm
I suspected. just didn't wanna be an asshole and say it since I wasn't sure.
PostSubject: Re: oily spark plugs?   oily spark plugs? Icon_minitimeFri Jan 14, 2011 8:18 pm
did you fix this david? I can tell you its definitley the valve cover gasket on that car if you havnt done it yet.
PostSubject: Re: oily spark plugs?   oily spark plugs? Icon_minitimeFri Jan 14, 2011 9:31 pm
no, I haven't yet. I totally forgot about it lol.
PostSubject: Re: oily spark plugs?   oily spark plugs? Icon_minitimeFri Jan 14, 2011 11:12 pm
On the 1.8 it takes like 10 minutes! hell you can reuse the gasket if it isnt cracked.
PostSubject: Re: oily spark plugs?   oily spark plugs? Icon_minitimeSat Jan 15, 2011 2:29 am
an OEM ford gasket for its not very much though, I could probly get it for under twenty
PostSubject: Re: oily spark plugs?   oily spark plugs? Icon_minitimeSat Jan 15, 2011 4:22 am
alright, I'll talk to her and see if she wants me to do it
oily spark plugs?
» Spark plugs. Stupid.
