 Turbo is in!
Go to page : Previous  1, 2
PostSubject: Re: Turbo is in!   Thu Feb 18, 2010 7:06 pm
I can check the cels for you tonight if youd like, its probably still your cam position sensor
PostSubject: Re: Turbo is in!   Thu Feb 18, 2010 7:09 pm
Yea that would be cool. I hope/think i found my boost issue, but before i sound like a dumbass ill check it out... lol.
PostSubject: Re: Turbo is in!   Thu Feb 18, 2010 7:42 pm
ha I hope it is what ever your thinking it is.
PostSubject: Re: Turbo is in!   Thu Feb 18, 2010 9:44 pm
I never used that cam sensor, let me know if you need it. It is in my spare parts bin.
spyderToph
PostSubject: Re: Turbo is in!   Fri Feb 19, 2010 10:41 am
Man these things are starting to look like nightmares. I hope you guys get everything worked out! Are you gonna tune it once you get the boost leak fixed?
PostSubject: Re: Turbo is in!   Fri Feb 19, 2010 12:07 pm
I fixed teh boost leak! I had the line between the wastegate and the turbo backwards Mad
It would only let me run wastegate pressure, or about 8 psi. Now that this issue if fixed, i need to get the wheel straightened, get at least that one new rim, then probably sell it. We'll see how this all turns out.
PostSubject: Re: Turbo is in!   Fri Feb 19, 2010 12:25 pm
PostSubject: Re: Turbo is in!   Fri Feb 19, 2010 2:36 pm
nah, when the car is half apart and you put it all back together, something is bound to be a little off. The boost leak on my car is minor, but for performance it is annoying when I hit 20 PSI and then it leaks a bit and the AFR dips rich and the boost drops to 18.5. Will be fixed soon enough. NASTI, if you need any help checking CELs or logging/tuning your car, give me a shout. I have a laptop with a bunch of open source tuning software
-Franz
PostSubject: Re: Turbo is in!   Fri Feb 19, 2010 2:40 pm
-Franz
Since i may be selling the car after i fix my tire thing, i may take you up on this. Just a few slight tweaks to make it run like new. Thanks for the offer.
Turbo is in!
Page 2 of 2Go to page : Previous  1, 2
