 odyssey battery pc680. anyone use them??
PostSubject: odyssey battery pc680. anyone use them??   Wed Jan 26, 2011 11:09 pm
i was thinking about buying one and have read mixed reviews...
http://www.odysseybatteries.com/battery/pc680.htm
PostSubject: Re: odyssey battery pc680. anyone use them??   Wed Jan 26, 2011 11:14 pm
that's actually the battery that I'll be getting for my Civic because the PW:JDM intake requires a smaller/relocated battery. they said they chose it for their kits because it "best suited their needs" or something. but I looked around as well on the 8th gen Civic forum and I didn't find anyone on there complaining about it.
PostSubject: Re: odyssey battery pc680. anyone use them??   Wed Jan 26, 2011 11:24 pm
yeah some people say they need to keep a tender on them if the car is sitting more than a week or so but those people might have a draw somewhere and dont know how to fix them. i get a very good discount and batteries plus, so let me know if your going to be getting one.
PostSubject: Re: odyssey battery pc680. anyone use them??   Wed Jan 26, 2011 11:27 pm
okay sounds good. are you looking into one for your hatch?
PostSubject: Re: odyssey battery pc680. anyone use them??   Wed Jan 26, 2011 11:31 pm
yeah, im not putting one under the hood for sure, not going to put weight behind the rear tires, and a fill size one will not clear the roll cage behind the pass. seat. so... im making a battery box that will pass cert and fit behind the seat.
PostSubject: Re: odyssey battery pc680. anyone use them??   Wed Jan 26, 2011 11:41 pm
i think tye has something like that.
PostSubject: Re: odyssey battery pc680. anyone use them??   Thu Jan 27, 2011 12:43 am
tyes only has like 300 CCA's or some ludicrisly low amount like that
PostSubject: Re: odyssey battery pc680. anyone use them??   Thu Jan 27, 2011 12:52 am
have you tried Kinetik batteries?
PostSubject: Re: odyssey battery pc680. anyone use them??   Thu Jan 27, 2011 1:41 am
Im pretty sure thats the same one I sold to tye and its worked fine for him, and me when I had it. I have a very similar one now and its sat for 3 months and started up my car fine the other day even though it took forever because of the cold start and e85.
PostSubject: Re: odyssey battery pc680. anyone use them??   Thu Jan 27, 2011 10:43 am
odysseys are very picky about their charging procedure, make sure you read up on it before you attempt to do it, i have one pc545 here thats crap from someone charging it like a regular battery.
i cant remember if its cheaper to get them from password or batteries plus either way i use them whenever possible. my buddy joe makes a nice aluminum case for em at his sheet metal shop too if you wanna save a couple bucks on the metal clad version.
PostSubject: Re: odyssey battery pc680. anyone use them??   Thu Jan 27, 2011 10:51 am
They're like $160 for just the battery from PW:JDM. So Batteries Plus is definitely cheaper.
PostSubject: Re: odyssey battery pc680. anyone use them??   Thu Jan 27, 2011 3:08 pm
i was talkin what i pay (been a p word dealer forever) compared to my dealer batteries + account.
ahhh, gotcha.
PostSubject: Re: odyssey battery pc680. anyone use them??   Thu Jan 27, 2011 7:39 pm
I have a DEKA 18L in my car.. 18 lb. 330 CCA
Braille are relabeled DEKA batteries. Odyssey are good too but more expensive and they didn't have the CCA I wanted
PostSubject: Re: odyssey battery pc680. anyone use them??   Thu Jan 27, 2011 8:20 pm
and she starts up and charges fine?
more info if it works good and would run my aem, CDI box, fan, 2 fuel pumps and headlights.
PostSubject: Re: odyssey battery pc680. anyone use them??   Thu Jan 27, 2011 11:18 pm
brad was runnin a 545 in his s13 with aem, elec fan, etc all fine. & lotsa honda guys out there runnin' em
PostSubject: Re: odyssey battery pc680. anyone use them??   Fri Jan 28, 2011 12:38 am
I haven't run my car much the last month, but I trickle charged the battery and dropped it back in last weekend. Cranked right up on the first one. I was kind of surprised. Before that, even around 0 degrees, it started the car no problem.
I got it locally from batteries plus.. It came with a 2 year warranty through them. So, if I have a problem they can replace it. I had to buy some SAE adapter terminals through them too.
http://www.batterymart.com/p-Big-Crank-ETX18L-Battery.html
PostSubject: Re: odyssey battery pc680. anyone use them??   Fri Jan 28, 2011 1:06 am
ok thanks nate and franz i was thinking about getting the odyssey 630 but if you say that other one is good i might try that. nate what do you get the 630 for to see if i get a better price at batt+... what terminals do you need to buy with that 18l battery?
PostSubject: Re: odyssey battery pc680. anyone use them??   Sat Jan 29, 2011 8:06 pm
Something like this:
Werker M6 to SAE Terminal Adapter
http://www.batteriesplus.com/p-23760-m6-to-sae-terminal-adapter.aspx
My car sat in the cold garage all week and it fired right up on the first crank yesterday.
PostSubject: Re: odyssey battery pc680. anyone use them??   Mon Jan 31, 2011 4:15 pm
ok im buying one today then. thanks for the info.
edit: on the way
PostSubject: Re: odyssey battery pc680. anyone use them??   Thu Feb 03, 2011 7:00 pm
I know I missed out on this thread, but I've had that battery for 2 years now and have no complaints.. I even have it tucked up under my dash.
PostSubject: Re: odyssey battery pc680. anyone use them??   Thu Feb 03, 2011 8:47 pm
sorry for being late but yea mine is only rated at like 300 CCA's or something like that but i tested it to be 400 CCA. it works great for the most part. when it gets cold (30* or so) it gets fussy but has never failed to start me. if it sits for several days it wont start but my year mustang has a problem with having draws, ford even put out a tsb on it. less than half the weight as the stocker, its a great buy.
PostSubject: Re: odyssey battery pc680. anyone use them??   Fri Feb 04, 2011 12:32 am
it will be here Monday thanks guys.
PostSubject: Re: odyssey battery pc680. anyone use them??   Fri Feb 04, 2011 1:43 pm
my battery just took a crap, i think ill be picking one of these up too
FP BLACK!
