 calling all subaru guys.
PostSubject: calling all subaru guys.   Sun Feb 13, 2011 5:50 am
if i ditch the cats on my wagon will it throw a check light for o2?
and what suspension are you guys running im slamming this thing out...
PostSubject: Re: calling all subaru guys.   Sun Feb 13, 2011 8:12 am
I have a "high flow" cat so I'm not sure on that one. I did not get one. Not sure if having no cats at all will throw one.
Suspension on mine is stock for the moment... I think you'll have to go coilovers if you want "slammed;" not sure though lol.
Ls240sx
PostSubject: Re: calling all subaru guys.   Sun Feb 13, 2011 10:42 am
I put wagon shocks and springs on my sedan to lift it Smile
http://Davidjlampe.com
PostSubject: Re: calling all subaru guys.   Sun Feb 13, 2011 11:32 am
my o4 had no cats whats so ever,no light.I put a set of tanebe gf 210's in it still lowered but kept the ride nice.Did do the pogo effect.Otherwise look into RCE blacks or yellows...
Leader of the BLACK CAR POSSE....
PostSubject: Re: calling all subaru guys.   Sun Feb 13, 2011 11:46 am
if its a 96+ obdII car it will throw a code.
PostSubject: Re: calling all subaru guys.   Sun Feb 13, 2011 11:47 am
If you don't get a reflash, it will throw a code.
if you run a Cobb map or similar, the code is disabled in the map.
I wouldn't recommend more than a 1" drop on stock struts for both performance and not killing the struts in 10k miles.
PostSubject: Re: calling all subaru guys.   Sun Feb 13, 2011 11:57 am
it's a '95
PostSubject: Re: calling all subaru guys.   Sun Feb 13, 2011 12:38 pm
yeah/ itts a 95 but it has an obd2 port sooooo.
PostSubject: Re: calling all subaru guys.   Sun Feb 13, 2011 1:23 pm
If there is an o2 sensor AFTER the converter, then yes, it will throw a code. The computer would see "dirtier air" from the 2nd o2 and think something is wrong.
This goes for all vehicles, not just a Subaru.
PostSubject: Re: calling all subaru guys.   Sun Feb 13, 2011 1:33 pm
You might want see if there is a way to simulate that the cat is working properly even though it isn't on the car. Maybe a 02 simulator or a way to just trick the 02 sensor.
PostSubject: Re: calling all subaru guys.   Sun Feb 13, 2011 3:17 pm
there is a trick with welding a washer on that i can show you sometime.
PostSubject: Re: calling all subaru guys.   Mon Feb 14, 2011 1:59 am
check an see if theres a secondary 02, if so i think i have some 02 eliminators around here somewhere/lmk
Ls240sx
PostSubject: Re: calling all subaru guys.   Mon Feb 14, 2011 5:47 pm
im pretty sure there was one narrow band sensor on my 95. Either way if there was 2 it would be a second narrow band so even if it wasnt there i dont think it would do anything. Subaru went with a narrow band front and wideband rear after 98
spyderToph
PostSubject: Re: calling all subaru guys.   Tue Feb 15, 2011 10:21 am
If you have a down-stream O2 then yes it will throw a code. A few options would be to install one or a few spark plug anti-foulers between the sensor and the exhaust pipe, two would be to install a resistor on the signal wire to simulate proper voltage (this is what I did), or three if you have the option, disable it with cobb or some other type of tuning software.
Ls240sx
PostSubject: Re: calling all subaru guys.   Tue Feb 15, 2011 11:04 am
its a 95
PostSubject: Re: calling all subaru guys.   Tue Feb 15, 2011 1:31 pm
Ls240sx wrote:
its a 95
still could have a down stream O2 sensor. all depends on when subaru started phasing in obd2 stuff to their cars.
PostSubject: Re: calling all subaru guys.   Tue Feb 15, 2011 2:29 pm
If it's a bolt on O2 sensor just get some longer bolts and pile up some washers to move the sensor out of the exhaust stream. Jew craft level 2 but it generally works.
