| cleaned the intercooler | |
+6Disgustang GGevoX 240sxguy Fuckin Schiller!! Tusk Thunderballs 10 posters |
Thunderballs Legit
| Subject: cleaned the intercooler Sun Mar 06, 2011 1:42 am | |
| So I decided to clean the intercooler / heat exchange on the lightning today. They have a less than stellar pcv system on them that causes some oil suction issues under boost. Anyway after what I can only assume as 70k miles of oil and other crap, this is what I found... Icky... Anyways I'm now running a catch can set up so it stays clean. Then upon inspection of the s/c I found someone tried to do some half assed cluster fuck job of a port job... When you send it to whoever to get it ported they essentially make a smaller hole below the big one. Well some twat waffle decided that he was going to do the same. Except he just used a drill and drilled 3 separate 5/8" holes. That's right, three separate holes... So I had to try and fix that, got it pretty close to what it should be. Didn't get a pic of that, but it was quite special. | |
| Subject: Re: cleaned the intercooler Sun Mar 06, 2011 1:53 am | |
| Glad you could fix the port job.
I used to scoff at catch cans until I got one last year. They do work. | |
| Subject: Re: cleaned the intercooler Sun Mar 06, 2011 2:08 am | |
| Subject: Re: cleaned the intercooler Sun Mar 06, 2011 10:27 am | |
GGevoX Legit
Posts : 154 Join date : 2010-10-09 Age : 36 Location : Madison
| Subject: Re: cleaned the intercooler Sun Mar 06, 2011 12:15 pm | |
| Thats pretty bad. At least it's not like the ss/sc cobalt crowd. When I had mine they used to self dremel the Eaton out. Some even JB weld the holes up to make it louder. It was always a hoot to watch someone pick up a used one and discover what a 16 year old did to it. Notice any temp difference yet? | |
Thunderballs Legit
| Subject: Re: cleaned the intercooler Sun Mar 06, 2011 12:34 pm | |
| I haven't logged yet. But I'm thinking it will be quite large. | |
| Subject: Re: cleaned the intercooler Sun Mar 06, 2011 12:36 pm | |
| I cleaned my intercooler yesterday also. Just a fun fact!! |
| Subject: Re: cleaned the intercooler Sun Mar 06, 2011 12:58 pm | |
| Race cars with your intercoolers......... | |
| Subject: Re: cleaned the intercooler Sun Mar 06, 2011 1:16 pm | |
| - GGevoX wrote:
- Thats pretty bad. At least it's not like the ss/sc cobalt crowd. When I had mine they used to self dremel the Eaton out. Some even JB weld the holes up to make it louder. It was always a hoot to watch someone pick up a used one and discover what a 16 year old did to it. Notice any temp difference yet?
well i can honestly say i would have never done that to mine. lol | |
| Subject: Re: cleaned the intercooler Sun Mar 06, 2011 3:36 pm | |
| I can't find my intercooler | |
| Subject: Re: cleaned the intercooler Sun Mar 06, 2011 4:57 pm | |
- Race cars with your intercoolers.........
That shit is too fancy. | |
| Subject: Re: cleaned the intercooler Sun Mar 06, 2011 10:45 pm | |
Race cars usually don't run a intercooler. | |
Mr Peepers Legit
Posts : 235 Join date : 2010-05-31 Location : Janesville
| Subject: Re: cleaned the intercooler Sun Mar 06, 2011 11:13 pm | |
Thunderballs Legit
| Subject: Re: cleaned the intercooler Sun Mar 06, 2011 11:36 pm | |
| Truth. Plus this is in a 4600 lb truck. So its nothing to worry about. | |
| Subject: Re: cleaned the intercooler Sun Mar 06, 2011 11:51 pm | |
| I have a big fat work truck turd too | |
| Subject: Re: cleaned the intercooler Mon Mar 07, 2011 9:14 am | |
| Air to water? Thought that's what all the big boys run. | |
| Subject: Re: cleaned the intercooler Mon Mar 07, 2011 9:17 am | |
- Air to water? Thought that's what all the big boys run.
It looks like it , looks just like the rousch supercharger I put on once. | |
| Subject: Re: cleaned the intercooler Mon Mar 07, 2011 9:22 am | |
| I know that one is but i was asking more about the really big boys. Don't they run air to water with the tank in the back filled with ice water? | |
| Subject: Re: cleaned the intercooler Mon Mar 07, 2011 9:42 am | |
- I know that one is but i was asking more about the really big boys. Don't they run air to water with the tank in the back filled with ice water?
Yep. Water intercoolers are pretty much just for drag racing. Most are fairly small capacity, meant just for a short blast. Very efficient, but only for a short duration. The stock ones used in the Fords are a joke. To say they are inefficient is an understatement. Better have a trunk full of icebags to keep adding to the reservior. |
Thunderballs Legit
| Subject: Re: cleaned the intercooler Mon Mar 07, 2011 9:52 am | |
| Really? Not trying to argue here but they really aren't that bad.
Upgrade the tank and you aren't sitting too bad.
The real problem with the stock system is the stock heaton s/c.
| Subject: Re: cleaned the intercooler Mon Mar 07, 2011 10:21 am | |
| Bigger tank capacity helps them out? Fair enough.
I'm basing my statement on two different Cobra Mustangs that I know of that the harder you ran 'em, the slower they went due to heat soak from the poor factory setup. |
Thunderballs Legit
| Subject: Re: cleaned the intercooler Mon Mar 07, 2011 11:38 am | |
| Yea that can still happen. Most of it is from the factory s/c. Outlet temps on the eaton can be huge. | |
| Subject: Re: cleaned the intercooler | |
