I've seen someone with an X with a slight drop run 275/35ZR18 on an 18x10.5. I would do that, but you could probably get away with a 265 without much stretch. I just remember working this out once before and the 275/35 will be closest to your stock outside diameter so your speedometer will still be accurate.
