 Build Thread suggestions.
PostSubject: Build Thread suggestions.   Wed Mar 03, 2010 12:52 am
If any of you have seen a build thread on another forum you have probably already seen this but I figured I would type one out for those new to it.
When starting a build thread it may be a good idea to reserve a few posts you can come back and edit to summarize the work you have done so people don't have to sift through all the posts. This makes it easy to summarize different areas of modification (i.e. Suspension, Power, Drive train, cosmetic, etc.). You can also add links to other pages for things like pictures as only so many will fit in a post and you will most likely always be taking pics of your car.
Just a suggestion, feel free to add yours to the thread Smile
Administrator
PostSubject: Re: Build Thread suggestions.   Wed Mar 03, 2010 1:05 am
Those are good suggestions, I can also lock the thread for anyone other than the OP or any mod can just delete others posts if necessary.
http://www.wistreetandtrack.com
