 Th3Franz's build
PostSubject: Th3Franz's build   Wed Mar 03, 2010 1:28 pm
2005 Subaru Legacy GT non-limited 5MT
Curb weight without driver: 3340 lbs
Stock hp/torque: 250/250
Estimated output, awaiting dyno: 320whp
Handling mods:
JDM GT Bilstein struts
JDM STI pink springs
JDM Cusco sway bars F&R (23, 21mm)
Whiteline solid end links
AVO rear sway bar reinforcements
SuperPro High Offset Caster control arm bushings
Whiteline poly steering rack bushings
Camber bolts (-1.9 camber up front for track)
DBA 4000 rotors F&R
Wilwood 4-pot Superlite front caliper kit
Porterfield R4-S street, PFC01 track
ATE Superblue brake fluid
Goodridge stainless lines
SSR Comp Type C 17x8.5 with 245/40/17 Dunlop Star Specs
Power mods:
Stage 3
BNR 20G TD05H Hybrid stock location
AVO Wastegate actuator set to 16 PSI
ID1000 injectors
T1Racing top feed fuel rail conversion
Aeroquip 6AN fuel lines
Fuelab mini regulator
Fuelab inline filter
Walbro 255LPH Fuel pump
Perrin TMIC
KSTech 73mm CAI with heat shield
Invidia 3" downpipe
PTP Turboblanket
JDM AVO mufflers
Grimmspeed ceramic coated up-pipe
Grimmspeed BCS in parallel with Hallman PRO MBC
Innovate LC-1 wideband O2
Custom open source tune thru SubyShop - 20 PSI
Drivetrain:
Cobb short throw shifter & hardened bushings
Redline & Motul gear oil
Cosmetic mods:
custom Carbon fiber grille
carbon fiber fog light delete
Momo shift knob
European arm rest extension
Apexcone 5000K HID kit
PIAA yellow fogs
Defi BF boost gauge
Zero-sports radiator shroud
Window tint all-around
SubyShop.com banners
Upcoming mods plans:
Rear end links
Brake ducts
PostSubject: Re: Th3Franz's build   Wed Mar 03, 2010 1:29 pm
reserved
reserved..
PostSubject: Re: Th3Franz's build   Wed Mar 03, 2010 1:46 pm
looks like you've been busy, quite the little list there.
PostSubject: Re: Th3Franz's build   Wed Mar 03, 2010 2:44 pm
Sounds like a fun car man!
PostSubject: Re: Th3Franz's build   Wed Mar 03, 2010 4:24 pm
I always look forward to driving it. Smile It will be a beast with a bit more hp and stopping power. heh just setting aside the budget for those things
On track action..
Surprising an STI, BMW 3, C6 Corvette
https://www.youtube.com/watch?v=hkJfjDsLkqs
Administrator
PostSubject: Re: Th3Franz's build   Wed Mar 03, 2010 4:35 pm
How does that Cobb STS feel? They have one for my car but its like 279 bucks so Im not sure its worth it.
http://www.wistreetandtrack.com
PostSubject: Re: Th3Franz's build   Wed Mar 03, 2010 4:36 pm
I have the old version of the Cobb STS.. not the newer CNC'd one, but it still gets the job done nicely
I like the adjustability of it, but 279 is a lot for an STS.. Does Kartboy or B&M make a short shifter for your car?
PostSubject: Re: Th3Franz's build   Wed Mar 03, 2010 10:42 pm
Hey that looks really fun! Ity sounds like a real good build, and I'm sure it can corner very well. Strong work! Smile
PostSubject: Re: Th3Franz's build   Fri Mar 19, 2010 1:44 pm
Posting up my punch list to do a week from now. fun stuff
2010 Race Season Punch List
• _ 5w40 Oil change & new key programming
• _ Gear oil swap - 2 qt Red line, 2 qt Motul
• _ Rear diff oil swap - Red line 75w90
• _ Power steering fluid flush
• _ Alignment at Stevens Point
• _ Swap to summer wheels
• _ Brake fluid flush - AMSoil
• _ Brake caliper inspection
• _ Carbon fiber for grille & brake ducts
• _ Brake duct install
• _ Oil supply line filter removal
• _ Wideband O2 gauge install
• _ Full auto wash & detail
• _ Register for Road America - April 17
PostSubject: Re: Th3Franz's build   Fri Mar 19, 2010 2:02 pm
Nice! I just bought the shockproof/motul mix for my tranny. Im using 3 parts shockproof and 1 part motul though. That stuff is crazy expensive.
PostSubject: Re: Th3Franz's build   Fri Mar 19, 2010 7:37 pm
Yeah I ordered a case of the Motul gear oil and got 2 quarts of the shockproof. Some of my friends are going to run straight Motul in their 6 speeds so it was worth getting a case
PostSubject: Re: Th3Franz's build   Tue Mar 30, 2010 11:47 pm
making progress. still have the ducts to do and drivetrain fluid flush
PostSubject: Re: Th3Franz's build   Wed Mar 31, 2010 12:43 am
Nice, I'll be making it to shawno on the 11th, I'll be in point the day before though.
PostSubject: Re: Th3Franz's build   Thu Apr 29, 2010 11:47 am
The build is paying off. Once I start a new job, I might kick things up another notch. We'll see.
Good times...
I love how the GT-R dwarfs my mid-size car... srsly that car is ginormous
PostSubject: Re: Th3Franz's build   Thu Apr 29, 2010 1:02 pm
car looks great. awsome track video as well
PostSubject: Re: Th3Franz's build   Fri Sep 24, 2010 1:13 am
Putting on some new parts this weekend. Here's a baseline dyno plot as the car stands right now from Kelly Moss' new dyno. Probably won't spend a whole lot more dyno time until I get some extra cash to upgrade the fuel system and turn up the boost
PostSubject: Re: Th3Franz's build   Fri Oct 01, 2010 1:51 pm
Installed the new ACT clutch and single mass flywheel last weekend. 600 miles later, all broken in and the clutch holds and feels great.
PostSubject: Re: Th3Franz's build   Sun Mar 06, 2011 9:48 pm
New build and fuel system is done and I'm almost done tuning the car. Feels pretty strong at 18 PSI and on pump gas I think I'll run 21 PSI peak. Some pics of the parts
PostSubject: Re: Th3Franz's build   Sun Mar 06, 2011 10:19 pm
Lookin good Smile
PostSubject: Re: Th3Franz's build   Sun Mar 06, 2011 10:25 pm
Maybe I'll even run some corn juice.. but dammit it sucks that the tracks don't have it closeby
PostSubject: Re: Th3Franz's build   Sun Mar 06, 2011 10:31 pm
Looks like a sweet car. Is it gonna be out on the lot this year ?
PostSubject: Re: Th3Franz's build   Sun Mar 06, 2011 10:46 pm
I hope it stays together! you are one of the few remaining original engines lol
From anything I've heard though you seem to know exactly what is going on and what you're doing.
Hope it get some good numbers.
PostSubject: Re: Th3Franz's build   Sun Mar 06, 2011 11:19 pm
nice build, looks like a fun ride.
PostSubject: Re: Th3Franz's build   Sun Mar 06, 2011 11:23 pm
When is yours gonna go zoom zoom kaboom? I think its a subaru thing
Th3Franz's build
