Subject: The Blackout Build Wed Mar 03, 2010 6:56 pm
Engine: 2.3L Turbo
Current Mods:
Engine:
Gutted Upper intake Knife Edged Lower 65mm Throttle Body EGR Delete Steeda AFPR Ported E-6 manifold T3-To4E .57trim compressor, .48 Turbine Stainless braided large diameter feed and return lines (oil) Semi-cold air intake Modified Air flow Meter Hallman Pro RX MBC set on "blow a fucking head gasket" Cleaned and Flowed Stock Injector (36PPH) Stinger FMIC kit Forge 004 BOV
Suspension:
Griggs Racing GR-40 Tubular K-member Griggs Racing FR-2000 Front Coilover kit with 350lb springs Custom strut mount plates Griggs racing Bumpsteer kit W/Heim joint tie rod ends Energy suspention poly sway bar links Griggs Racing GR-40 Forward Offset A-arms with delrin bushings FRPP Balljoints KB Welded Subframe Connectors Southside machine Lift Bars with Delrin/Steel bushings Custom Welded Torque Boxes (1/4 and 1/8 inch steel plate) Eibach Non-Adjustable rear swaybar (thick as shit)
Exhaust:
Stock Diameter (2.5") Downpipe with Gutted Cat 2.5" Midpipe (no Muffler) 2.5" mandrel bent Tailpipe with magnaflow rolled tip
Brakes:
Stock rears Lincoln Mark VII Front calipers (Phenolic)
Drivetrain:
Centerforce Dual Friction Clutch kit New Severe Duty U-joints Balanced and lightened Driveshaft New Tailshaft bushing on the Trans Rebuilt World Class Borg Warner T-5 FRPP 3.55 gears with new clutch packs Redline Synthetic Trans fluid Amsoil 90wt Gear oil + modifier in the 8.8
Parts for this Spring (yet to be installed)
Boport Racing stage 1.5 Cam Esslinger Adjustable Cam Pulley Stiffer Spring For the Hallman MBC Maximum Motorsports Caster/Camber plates Maximum Motorsports Front Swaybar Relocation kit KYB AGX front Struts Zeitronix Wideband w/display + 5 bar MAP sensor EGT probe
Still Searching For:
.63 Hot Side for my T-3 A Fucking blowoff valve that I don't have to constantly adjust A Pair of Mustang Turbine wheels to mount the DR's to.
Subject: Re: The Blackout Build Wed Mar 03, 2010 6:56 pm
{reserved}
{Reserved}
{Reserved}
Subject: Re: The Blackout Build Wed Mar 03, 2010 10:01 pm
Someday I'll see this car, some day.
Subject: Re: The Blackout Build Wed Mar 03, 2010 10:41 pm
Blackout
Wow, nice list of mods. I can completely understand why you can't wait for summer. How much does that catr weigh?
Subject: Re: The Blackout Build Wed Mar 03, 2010 11:39 pm
Last time I weighed it.......3360 with around 50Lbs of tools, and at least 50lbs of subwoofer/box/and amp.... and 1/2 tank of fuel. My best guess is that If I took all that out and dropped it to about 1/4 tank, it would be right around the low 3200's.
I just looked back at my mod list......Jesus i spend too much money......LOL
Subject: Re: The Blackout Build Wed Mar 03, 2010 11:40 pm
LOL its really not that special...... And its *i think* the second oldest car on this site...... along with one of the slowest!
Subject: Re: The Blackout Build Thu Mar 04, 2010 8:49 am
^ But you don't see too many of them anymore let alone with you mods. Looks like it's in really nice shape too.
Subject: Re: The Blackout Build Thu Mar 04, 2010 7:13 pm
Thats very true.... but I have to do something about the rust issues this year. i've waited too long as it is. Its getting bad around the rear wheel wells and at the bottom of the doors. if i don't do something this year, there won't be any point in modifying the car further. At that point I'd be looking for a clean roller.
Subject: Re: The Blackout Build Fri Mar 26, 2010 2:37 am
I Just got quoted on body work - paint ( I can shoot paint). 400 Bucks. Not too bad. Now, I need to get ahold of the gook with that RFL BOV, get my center stack trim back from Radio Docter and have Nate put in a wideband bung for me. 29th thru the 4th its going under the knife, so you all will see it around sometime after that!
Subject: Re: The Blackout Build Fri Mar 26, 2010 2:38 am
LOL! When I type T I M it comes out the gook??? LOL Thats the funniest shit I've seen in a long time!
Subject: Re: The Blackout Build Fri Mar 26, 2010 9:40 am
the gook
Subject: Re: The Blackout Build Fri Mar 26, 2010 9:41 am
HOLY SHIT ^^ LMAO
God forbid another "tim" joins
Nice car BTW, I had the chance to check it out last summer. How is the amp working out for you?
Subject: Re: The Blackout Build Sun Mar 28, 2010 10:09 pm
You drove past my house today, That BOV is loud as fuck and your exhaust sounds great. Very nice man.
Subject: Re: The Blackout Build Mon Mar 29, 2010 5:10 am
LOL nothing like a straight pipe to wake ya up!
First time out with the RFL on, I'll have to let the gook know that it works great!
Subject: Re: The Blackout Build Mon Mar 29, 2010 5:11 am
HOLY SHIT ^^ LMAO
The amp was absolutely perfect for that Eclipse Sub i have, and is still working flawless! Thanks again!
U LK2LSE
Posts : 207 Join date : 2010-06-06 Age : 37 Location : Madison
Subject: Re: The Blackout Build Tue Jun 29, 2010 4:57 am
I wanna see your bird do this....
only a 2.7 with 39 pounds of boost...
Subject: Re: The Blackout Build Tue Jun 29, 2010 9:44 am
is that the one that did drag week last year or this a different one? either way those 4 cylinder fords can be pretty bad ass
Subject: Re: The Blackout Build Tue Jun 29, 2010 6:34 pm
I'm pretty sure that's John Hubers' car. Its bad ass. My car will never be that fast.
I'm hoping for low 12's to high 11's EVENTUALLY...... thats after a whole lot more money put into it. I have a wierd electrical issue now, so the car isnt actually running as we speak.
F M L
Subject: Re: The Blackout Build Fri Jul 02, 2010 12:05 am
Fixed the issue, and took some fuel out of it. Runs pretty strong, but I'd like to get it on the rollers to make sure I don't break anything!
20 PSI feels pretty good, but I might bump that up a bit higher depending on how the engine likes it.
Subject: Re: The Blackout Build Thu Sep 16, 2010 12:52 am
Okay. Changed out the Turbo with a better sized unit, Adjusted fuel pressure, and I still need to dial some timing into it.
I'm thinking i'll set it at about 20PSI for now, or it will start running over the stock injectors.
It runs good, and felt pretty strong at 10PSI, so we will see if I can bump it up a bit and make it fairly quick.
