 New to site,Ryan97 gsr ek
Vanilla Gorilla
24 posters
Go to page : 1, 2, 3, 4  Next
New to site,Ryan97 gsr ek Empty
PostSubject: New to site,Ryan97 gsr ek   New to site,Ryan97 gsr ek Icon_minitimeWed Feb 09, 2011 8:25 pm
My name is Ryan and this is my 1997 coupe(was my first car). It all started with me asking Bryan Johnson to "vtec" my stock single cam at age 16. After his harsh answer i decided to hit the books and look up what was "cool" to do with a honda so not long after i called him asking to show me how to do a b series swap(LS). Made many new friends and got into the addicting habit of building cars.
*****This build thread is one from last year, new plans over the winter so i will be updating with pictures****
-does not have the flashback wheels anymore
-slappin a turbo kit on
GENERAL INFO
*innovative mounts with stiff bushings(no marshmellow bushings)
*all mounts and brackets were powdercoated black
* si front end and bumper
*Pioneer Deck
*Custom clutch line that runes behind the firewall, through the frame and to the slave cyl.
*Tucked brake lines(all mounted and riveted) kept heat
-chasebays coated brakelines with A/N fittings
-willwood master with a booster delete plate(stiff pedal, stops great)
-Integra prop valve
*integra brakes all the way around
*new pads, rotors (anything brake related has pretty much been replaced)
SUSPENSION
*Koni Yellow/Ground Control (bought new, great condition)
*Rota flashbacks Falken 912 tires
*Extended top hats
*ASR subframe brace(black)
*function 7 black lca's
*ASR swaybar
*blox camber/toe kits(everything)
*new wheel bearings
*extended studs
*buddyclub lugnuts
_A lot of suspension and brake work has been replaced and upgraded, handles amazing_
MOTOR
208hp 150tq GSR "stroker"
( power peaks at 7700 rpm because of compression and cam combo)
*E85
*B18c1 (81.5 mm)
*type R trans(LSD)
*ls crank
*Eagle rods with upgraded bolts
*mahle 10.5.1 pistons
*all new waterpump,timingbelt,oilpump,gaskets, etc.
*supertech springs
*supertech retainers
*supertech keepers
*supertech valve seals
*supertech flat face high compression valves
*skunk2pro2 cams
*precision 580cc injectors
*new oem headgasket
*ARP headstuds
*blackworks full size aluminum radiator
*samco radiator hoses
*STR adjustable cam gears/cam cap
*Blox intake manifold(port matched to throttle body)
*Omni 70mm Throttle boddy
*aluminum catch can with black braided lines and fittings
*kiddracing replica header(2 1/2 inch collector)
*full stainless tig welded custom 3” exhaust all the way to the rear bumper with a turndown.(exhaust built for boost so it is loud now)
INTERIOR
*Bride seats (black with gradation) Replicas but are very nice
*G FORCE 5 pt harnesses with twist lock
*dash/carpet/doorpanels and all plastics are black
*Tucked fuse box(NO AIRBAGS, fusebox is in the airbag location)
*Battery relocation
*CTR cluster(amber)
*Rollbar
*nrg quick release
*nrg hub
*nardi suede replica wheel
New to site,Ryan97 gsr ek Civic2
Pictures aren't really in the order of oldest to newest or anything
(the bumper with holes is no longer on the car, it has a new si bumper)
New to site,Ryan97 gsr ek DSC_1328
New to site,Ryan97 gsr ek DSC_1330
New to site,Ryan97 gsr ek DSC_1331
New to site,Ryan97 gsr ek DSC_1332
New to site,Ryan97 gsr ek DSC_1329
New to site,Ryan97 gsr ek DSC_1333
New to site,Ryan97 gsr ek DSC_1335
New to site,Ryan97 gsr ek DSC_1336
New to site,Ryan97 gsr ek DSC_1338
New to site,Ryan97 gsr ek DSC_1340
New to site,Ryan97 gsr ek CAR-2
New to site,Ryan97 gsr ek DSC_1315
New to site,Ryan97 gsr ek DSC_1317
New to site,Ryan97 gsr ek DSC_1305
New to site,Ryan97 gsr ek CAR-1
*a few motor build pictures from previous cams*
New to site,Ryan97 gsr ek DSCF1812
New to site,Ryan97 gsr ek DSCF1816
New to site,Ryan97 gsr ek DSCF1817
New to site,Ryan97 gsr ek DSCF1824
New to site,Ryan97 gsr ek DSCF1839
New to site,Ryan97 gsr ek DSCF1841
New to site,Ryan97 gsr ek DSCF1902
now for some that are a little older
New to site,Ryan97 gsr ek 103_0272
New to site,Ryan97 gsr ek DSCF1601
New to site,Ryan97 gsr ek DSCF1604
PostSubject: Re: New to site,Ryan97 gsr ek   New to site,Ryan97 gsr ek Icon_minitimeWed Feb 09, 2011 8:34 pm
PostSubject: Re: New to site,Ryan97 gsr ek   New to site,Ryan97 gsr ek Icon_minitimeWed Feb 09, 2011 8:40 pm
Welcome dude, looks like a nice build, this is how a Honda should be built!
PostSubject: Re: New to site,Ryan97 gsr ek   New to site,Ryan97 gsr ek Icon_minitimeWed Feb 09, 2011 10:06 pm
Nice EK. I know I've seen this car around last summer.
PostSubject: Re: New to site,Ryan97 gsr ek   New to site,Ryan97 gsr ek Icon_minitimeWed Feb 09, 2011 10:10 pm
welcome nice build
fuckin' ricers Smile
PostSubject: Re: New to site,Ryan97 gsr ek   New to site,Ryan97 gsr ek Icon_minitimeWed Feb 09, 2011 10:11 pm
welcome, clean ride.
PostSubject: Re: New to site,Ryan97 gsr ek   New to site,Ryan97 gsr ek Icon_minitimeWed Feb 09, 2011 10:12 pm
Nice build. Is like to learn more about this kind of stuff ......thanks for posting this up. I wish I could put my build threads up to share
PostSubject: Re: New to site,Ryan97 gsr ek   New to site,Ryan97 gsr ek Icon_minitimeWed Feb 09, 2011 10:32 pm
once the parts come in he ordered pics should be up of the turbo magic cock pony.
PostSubject: Re: New to site,Ryan97 gsr ek   New to site,Ryan97 gsr ek Icon_minitimeWed Feb 09, 2011 10:39 pm
i gotta get pics of the new wheels too
PostSubject: Re: New to site,Ryan97 gsr ek   New to site,Ryan97 gsr ek Icon_minitimeWed Feb 09, 2011 10:40 pm
clean honda man. Pretty sure ive seen it around.
PostSubject: Re: New to site,Ryan97 gsr ek   New to site,Ryan97 gsr ek Icon_minitimeWed Feb 09, 2011 11:00 pm
thats the cleanest honda/import ive seen in long ass awhile. that was at my 10th anniv. show 2 septembers ago i think? i was impressed, still have that crappy trophy? Wink
PostSubject: Re: New to site,Ryan97 gsr ek   New to site,Ryan97 gsr ek Icon_minitimeWed Feb 09, 2011 11:29 pm
Thanks for all the comments, yah that trophy got destroyed by a drunk buddy, lol
PostSubject: Re: New to site,Ryan97 gsr ek   New to site,Ryan97 gsr ek Icon_minitimeWed Feb 09, 2011 11:43 pm
thats strange i still havent found a book to make a honda cool. lol. just kidding man. if there is a way to make a honda cool those DTP guys are the ones to go to. looks like a pretty bad ass build
PostSubject: Re: New to site,Ryan97 gsr ek   New to site,Ryan97 gsr ek Icon_minitimeWed Feb 09, 2011 11:51 pm
thats a clean civic, I remember seeing this car last year
PostSubject: Re: New to site,Ryan97 gsr ek   New to site,Ryan97 gsr ek Icon_minitimeThu Feb 10, 2011 12:14 am
what up...
PostSubject: Re: New to site,Ryan97 gsr ek   New to site,Ryan97 gsr ek Icon_minitimeThu Feb 10, 2011 12:37 am
What's with the holes in the rear bumper?
PostSubject: Re: New to site,Ryan97 gsr ek   New to site,Ryan97 gsr ek Icon_minitimeThu Feb 10, 2011 1:08 am
he had a magic cock pony bumper and we were going to the track... less weight, less drag, simple concept..
PostSubject: Re: New to site,Ryan97 gsr ek   New to site,Ryan97 gsr ek Icon_minitimeThu Feb 10, 2011 5:32 am
I like yo wims. Keep the blue Cool .. welcome!
PostSubject: Re: New to site,Ryan97 gsr ek   New to site,Ryan97 gsr ek Icon_minitimeThu Feb 10, 2011 12:03 pm
john's son?? sold the blue wheels since they were the only "flashy" things on the car.
PostSubject: Re: New to site,Ryan97 gsr ek   New to site,Ryan97 gsr ek Icon_minitimeThu Feb 10, 2011 1:05 pm
Yup that's me lol.
PostSubject: Re: New to site,Ryan97 gsr ek   New to site,Ryan97 gsr ek Icon_minitimeThu Feb 10, 2011 2:40 pm
Hmm... Sounds like you should bring your holesaw over and do some cutouts in the bumper of my Buick. Maybe then I can get into the 14s... Twisted Evil
To the OP, nice car..... For a rice rocket Honduh Wink
PostSubject: Re: New to site,Ryan97 gsr ek   New to site,Ryan97 gsr ek Icon_minitimeThu Feb 10, 2011 3:54 pm
still looks sweet
PostSubject: Re: New to site,Ryan97 gsr ek   New to site,Ryan97 gsr ek Icon_minitimeThu Feb 10, 2011 4:47 pm
k. you want 3 or 4 inch? rabbit
PostSubject: Re: New to site,Ryan97 gsr ek   New to site,Ryan97 gsr ek Icon_minitimeThu Feb 10, 2011 5:53 pm
^ I'd go 4"
Page 1 of 4Go to page : 1, 2, 3, 4  Next
