| Eclipse Gst | |
Posts : 354 Join date : 2011-05-23
| Subject: Eclipse Gst Thu Aug 04, 2011 8:26 pm | |
| Finally got the ambition to rip apart the eclipse i bought about a week about. Here are some pictures from todays work. Bumper cover and etc. out of the way. Engine and tranny coming out. Empty engine bay She's dirty | |
347 LX Legit
| Subject: Re: Eclipse Gst Thu Aug 04, 2011 8:47 pm | |
| I like that you work outside... | |
| Subject: Re: Eclipse Gst Thu Aug 04, 2011 8:52 pm | |
| Thanks that's only temporary i hope. | |
| Subject: Re: Eclipse Gst Fri Aug 05, 2011 1:24 am | |
| The grabber green paint is hot. | |
| Subject: Re: Eclipse Gst Fri Aug 05, 2011 12:28 pm | |
| Yeah with that hot green color paint i figured it wasn't stock. But i just took the head off and sure enough 63dt pistons or in other words stock 1g pistons. | |
| Subject: Re: Eclipse Gst Fri Aug 05, 2011 5:59 pm | |
| Looks like someone did a 6 bolt swap in the past? | |
| Subject: Re: Eclipse Gst Fri Aug 05, 2011 7:11 pm | |
| Yep quite a few owners back. The body has 198,000 miles on it. | |
| Subject: Re: Eclipse Gst Fri Aug 05, 2011 7:22 pm | |
| Little update, last night my allen socket busted in half so i had to wait until today to take the head off. Picture of broken allen socket Head off I'm guessing this gear is for the oil pump? When i took off the timing cover the belt was no where to be found. Transmission off Donor 6bolt in the trunk Engine out of the trunk Thats about all i felt like doing today. Now its off to the casino wish me luck. | |
| Subject: Re: Eclipse Gst Fri Aug 05, 2011 7:48 pm | |
| That gear is the front balance shaft. The oil pump is driven by the timing belt and its the sprocket on the far lower right. The oil pump also drives the rear balance shaft. | |
| Subject: Re: Eclipse Gst Fri Aug 05, 2011 7:50 pm | |
| Thanks i'm kinda of a noob in the 4g63 world. lol | |
| Subject: Re: Eclipse Gst Fri Aug 05, 2011 8:14 pm | |
| haha no problem. Get on dsmtuners.com and they have basically any information you would want to know. | |
| Subject: Re: Eclipse Gst Fri Aug 05, 2011 10:17 pm | |
| +1 on joining dsmtuners. The previous owner must have done a balance shaft delete. That would explain why there was no belt on the gear. Having the 6 bolt is a huge benefit. Was the engine in the car (the green one) magic cock pony? | |
| Subject: Re: Eclipse Gst Sat Aug 06, 2011 3:57 am | |
| i spy an act in there/dont put that turd in anything until you check the crank thrust bearings. well unless you wanna pull it again. | |
| Subject: Re: Eclipse Gst Sat Aug 06, 2011 3:22 pm | |
| - bigbird94 wrote:
- +1 on joining dsmtuners. The previous owner must have done a balance shaft delete. That would explain why there was no belt on the gear. Having the 6 bolt is a huge benefit. Was the engine in the car (the green one) magic cock pony?
Yeah the green one took a crap lol. Haven't pulled the oil pan but i'm pretty sure its a rod bearing. | |
| Subject: Re: Eclipse Gst Sat Aug 06, 2011 3:27 pm | |
| - ma70tt wrote:
- i spy an act in there/dont put that turd in anything until you check the crank thrust bearings. well unless you wanna pull it again.
By act, you mean the clutch/pressure plate? | |
347 LX Legit
| Subject: Re: Eclipse Gst Sat Aug 06, 2011 7:23 pm | |
| I've got the exact same impact gun! | |
| Subject: Re: Eclipse Gst Sat Aug 06, 2011 11:45 pm | |
| - 347 LX wrote:
- I've got the exact same impact gun!
I love that impact its my favorite tool lol next to my 3/8 snap on ratchet. | |
| Subject: Re: Eclipse Gst Sun Aug 07, 2011 7:34 pm | |
| Subject: Re: Eclipse Gst Sun Aug 07, 2011 10:36 pm | |
| Subject: Re: Eclipse Gst | |
| Eclipse Gst | |
