It's going to be a basic motor build with a little juice to back it up, here are the basics (a lot more goes into it, but cam specs and shit like that are boring)
Eagle stroker kit 390 ci 11.4;1 compression
Eagle Armor coat crank $150.00
Patriot LS6 Stage 2 heads
Custom Cam grind Crower cam
Gold Race rocker arms
Double roller timing chain
Hardened push rods
Fast 102 mm intake manifold and throttle body
Spec Clutch stage 3
Spec Flywheel
Fast injectors
Dynatech headers
Magnaflow exhaust
K&N intake
Dyno Tune
Bear eradaspeed rotors
Hawke pads
Goodrich braided steel lines
some kind of kick-ass tires
maybe a little of the NOS
