| Thermal-ceramic coating? | |
mkiiichip Legit
Posts : 25 Join date : 2012-03-04
| Subject: Thermal-ceramic coating? Thu Apr 19, 2012 7:27 pm | |
| I am looking for a place that does ceramic coating for turbo parts. The manifold and downpipes are fairly straight forward, but the turbine housing will take a fair amount of knowledge, to coat properly.
Anyone have any experience with a shop somewhere in wi?
Thanks. | |
| Subject: Re: Thermal-ceramic coating? Fri Apr 20, 2012 3:00 pm | |
| I've done the diy stuff with legasti on his exhaust housing so far so good. There are a few tricks to getting it to stay though | |
| Subject: Re: Thermal-ceramic coating? Fri Apr 20, 2012 3:57 pm | |
| Don't you need to bake that stuff on at some ridiculously high temperatures? | |
| Subject: Re: Thermal-ceramic coating? Fri Apr 20, 2012 3:59 pm | |
| This has come up before, I used Jethot and was very happy with the quality. That or swaintech would be my only two real choices if I were looking to hold heat in. It's expensive but it was worth it. | |
| Subject: Re: Thermal-ceramic coating? Fri Apr 20, 2012 8:24 pm | |
| - 2jz-U-Ltr wrote:
- Don't you need to bake that stuff on at some ridiculously high temperatures?
Yes 3 times at 500 or 450 in our case because that's how hot our oven could get. Also media blasting it first isa must | |
mkiiichip Legit
| Subject: Re: Thermal-ceramic coating? Sat Apr 21, 2012 6:22 pm | |
- This has come up before, I used Jethot and was very happy with the quality. That or swaintech would be my only two real choices if I were looking to hold heat in. It's expensive but it was worth it.
I did search, the word "ceramic" turned up zero results. It seems that will be the way i'll go. - Overboosting wrote:
Yes 3 times at 500 or 450 in our case because that's how hot our oven could get. Also media blasting it first isa must Media blasting is a definite, but i dont see how you can bake a product onto a manifold at 500, and expect it to withstand temps in the 1000+ range. | |
| Subject: Re: Thermal-ceramic coating? Sat Apr 21, 2012 7:20 pm | |
| why not? That cures it, then it can handle more. | |
| Subject: Re: Thermal-ceramic coating? Sat Apr 21, 2012 8:28 pm | |
| I always thought that legit ceramic coat had to be heated to like 1500 degrees but I have no real knowledge of it | |
| Subject: Re: Thermal-ceramic coating? Sat Apr 21, 2012 8:54 pm | |
| MKiii
I think this came up on a different forum now that you mention it. I still recommend jet-hot. | |
| Subject: Re: Thermal-ceramic coating? Sat Apr 21, 2012 9:25 pm | |
| The search function on this forum is 100% useless | |
| Subject: Re: Thermal-ceramic coating? Sun Apr 22, 2012 2:23 am | |
| - 2jz-U-Ltr wrote:
- The search function on this forum is 100% useless
Much like most of the people myself included. | |
| Subject: Re: Thermal-ceramic coating? Sun Apr 22, 2012 8:06 am | |
| Tech-line coatings has what your looking for also. | |
| Subject: Re: Thermal-ceramic coating? Sun Apr 22, 2012 9:14 am | |
Much like most of the people myself included. Zing! | |
| Subject: Re: Thermal-ceramic coating? | |
