 RCA Connectors
Go to page : Previous  1, 2, 3  Next
franky.C
PostSubject: Re: RCA Connectors   Wed Apr 07, 2010 11:39 pm
where did u get em guy?
PostSubject: Re: RCA Connectors   Thu Apr 08, 2010 7:56 am
$0.02 says radio doctor.
I'm telling ya...... When I modeled it up in a 5 cu ft @ 20hz ported box it was pretty damn sexy. Tuning higher looked frightening Smile
I have a three day weekend next weekend, might have to build another spare tire box Wink I just don't want to screw up what I've got going with my stereo right now. I'm pretty damn happy with it.
Franky, what are you running..... all these closet stereo people need to share Smile
PostSubject: Re: RCA Connectors   Thu Apr 08, 2010 8:25 am
Yeah it was Radio Doctor, they love that Memphis shit. I'm down to take you or Evan up on some help tapping into that source anytime. Other than that part I'm good to go.
PostSubject: Re: RCA Connectors   Thu Apr 08, 2010 8:46 am
Peter, you got a link to that info you were talking about?
PostSubject: Re: RCA Connectors   Thu Apr 08, 2010 9:04 am
Yeah man, as soon as I get off this plane. My phone sucks a dick at copy and paste
OH, I didn't know you weren't back yet.
PostSubject: Re: RCA Connectors   Thu Apr 08, 2010 9:06 am
I'm about halfway, the flight attendant is hot as hell, I'm gonna try and get her pic but it won't be easy with the fat beast sitting next to me in the way.
PostSubject: Re: RCA Connectors   Thu Apr 08, 2010 9:13 am
Oh hell yeah. I didn't know you were allowed to use the interwebz from an airplane. Pretty sweet.
franky.C
PostSubject: Re: RCA Connectors   Thu Apr 08, 2010 5:29 pm
two 12'inch Kicker CVR's. on a 1500 Watt Sony Xplode amp..or something like that, im pretty sure though
PostSubject: Re: RCA Connectors   Thu Apr 08, 2010 7:49 pm
Here is the first write up I found, I think this makes sense........
Unbolt driver's seat and tip it back and out of the way
See the wiring harness for the Bose amp below
The plug with 4 wires is where you tap into to get the music signal.
Gently pull this plug out of the amp. Don't mess with the red or black.
The other two wires (white with blue stripe and gray) you will tap and
run wires from those to the high level input on your amp. (If you
purchase an amp with a high level input, you won't need to buy a LOC)
The high level input offers a less distorted signal too.
In order for the amp to know to power on/off when the car is turned
on/off you need to tap into the "remote signal" you find this on the the
wiring harness with the blue plastic tabs. Start by gently pulling this
harness out of the amp. There is a series of wires in the top half of
the harness and another series on the bottom of the harness. You are
looking for the solid blue wire on the bottom half of the harness. Tap
into this and run it to your amp.
Now run your speaker wire to your sub.
PostSubject: Re: RCA Connectors   Thu Apr 08, 2010 7:57 pm
Looks like a piece of cake Smile
Just nosy.... do you have access to an actual wiring diagram?
PostSubject: Re: RCA Connectors   Thu Apr 08, 2010 8:00 pm
Peter when are you doing this? Ill come over and stand around while you work, ive gotta grab some of your double sided sticky tape for one of my own projects too.
PostSubject: Re: RCA Connectors   Thu Apr 08, 2010 8:07 pm
Here is a little more info on the second plug. I, however don't really know what's best
Expose the wire harness and get to work. The one still plugged in is the
sub power and pre-outs. Here is a Bose wiring diagram I stole from
another site. Maybe things change year to year because it wasn't bang on
but I got it the first time using some common sense.
TOP
grey w/ red stripe (FR-)
white w/ red stripe (FR+)
grey w/ black stripe (FL-)
white w/ black stripe (FL+)
solid grey (BR-)
solid white (BR+)
grey w/ white stripe (BL-)
white w/ purple stripe (BL+)
BOTTOM
solid blue (remote turn on)
solid purple (FL+)
green w/ white paint (FL-)
solid red (FR+)
solid green (FR-)
brown w/ blue stripe (BL+)
yellow w/ blue stripe (BL-)
yellow w/ green stripe (BR+)
white w/ blue stripe (BR-)
PostSubject: Re: RCA Connectors   Thu Apr 08, 2010 8:12 pm
PostSubject: Re: RCA Connectors   Thu Apr 08, 2010 8:20 pm
Ok so since my amp has a high level input next to the RCA input, can't I just use that as a source? I have a connector with bare wires on the other end for tapping the wires if that will work.
PostSubject: Re: RCA Connectors   Thu Apr 08, 2010 8:21 pm
The only downside of that link is that it is for a mazda 3, which does not use the bose factory system
PostSubject: Re: RCA Connectors   Thu Apr 08, 2010 8:27 pm
Just use the high level inputs. You got an amp power wire kit correct Wink Try and get the good 3M wire taps, if taping is the way it is going to go.
What amp did you get?
PostSubject: Re: RCA Connectors   Thu Apr 08, 2010 8:28 pm
^ agreed, provided those subwoofer wires listed are high level (which I assume they are).
PostSubject: Re: RCA Connectors   Thu Apr 08, 2010 8:48 pm
it's a memphis PR2X100
PostSubject: Re: RCA Connectors   Thu Apr 08, 2010 9:19 pm
I appreciate all the feedback on this, but I'm still gonna need to swing by and get some help. The high level input has five wires, I'm only splicing into two I think....i don't know. UNCLE
PostSubject: Re: RCA Connectors   Thu Apr 08, 2010 9:21 pm
I'm free Sunday...... anyone else up for this sooner?
PostSubject: Re: RCA Connectors   Thu Apr 08, 2010 9:32 pm
I'm pretty much free anytime so sunday is cool with me man
PostSubject: Re: RCA Connectors   Thu Apr 08, 2010 10:23 pm
Well, what I have laying around is a RF converter. Basically, you hook it into your line level outputs either at the back of the factory stereo or the factory amp, and it converts to two sets of RCA outputs. It has level controls too..... I never tried it out... but it was hooked into my aftermarket deck in my exploder when I got it... apparently they used it with the factory deck to hook up an amp for subs. If you want it, its yours.
PostSubject: Re: RCA Connectors   Fri Apr 09, 2010 7:48 am
I'll pencil you in Smile
You have the amp kit in already?
PostSubject: Re: RCA Connectors   Fri Apr 09, 2010 8:41 am
Sorry guys, I am out this weekend. I have to go back to IL to go see my grandmother in the hospital. Ill likely be there all weekend. She has pneumonia and to be honest, the prognosis is not good.
If something comes up and tusk can't help you out I can likely do it next week.
Sorry!
RCA Connectors
Page 2 of 3Go to page : Previous  1, 2, 3  Next
