| Drill Press | |
| Subject: Drill Press Tue Jun 08, 2010 1:04 am | |
| Anyone have a drill press I can use to drill out a bolt? I have my own bits, but I don't have any cutting lube. Go ahead with the lube pictures. | |
| Subject: Re: Drill Press Tue Jun 08, 2010 5:01 am | |
| I take it you need a domestic drill press? |
| Subject: Re: Drill Press Tue Jun 08, 2010 6:02 am | |
| It's that or just create a whole new section called non-denominational garage | |
| Subject: Re: Drill Press Tue Jun 08, 2010 8:49 am | |
| I got one you can use. It's in Brodhead |
| Subject: Re: Drill Press Tue Jun 08, 2010 12:25 pm | |
| i have one, in cross plains, lemme know |
| Subject: Re: Drill Press Tue Jun 08, 2010 3:48 pm | |
| Subject: Re: Drill Press Tue Jun 08, 2010 4:01 pm | |
| I know dude, but I know you have a sprog on the way and that might make your life a little more hectic | |
| Subject: Re: Drill Press Tue Jun 08, 2010 4:32 pm | |
| Peter, I have one too. I would have to fix it first, but this is good motivation to do so. The motor pulley isn't installed.
What are you drilling/fixing? | |
| Subject: Re: Drill Press Tue Jun 08, 2010 4:36 pm | |
| I'm drilling out a bolt to create a banjo bolt fitting that will restrict some oil flow to my turbo | |
| Subject: Re: Drill Press Tue Jun 08, 2010 4:38 pm | |
| Why not just weld up the holes in your stock banjo and drill restrictor holes in that? Hell of a lot easier. I have a welder btw. That is how I did mine. | |
| Subject: Re: Drill Press Tue Jun 08, 2010 4:39 pm | |
| Well I don't have a welder or welding skillz, but if that is an offer to help I will bring the drinks | |
| Subject: Re: Drill Press Tue Jun 08, 2010 4:47 pm | |
| Subject: Re: Drill Press Tue Jun 08, 2010 10:02 pm | |
| if you guys wanna make a night (or day) of it i have the equipment. | |
| Subject: Re: Drill Press | |
| Drill Press | |
