 Drill Press
4 posters
Drill Press Empty
PostSubject: Drill Press   Drill Press Icon_minitimeTue Jun 08, 2010 1:04 am
Anyone have a drill press I can use to drill out a bolt? I have my own bits, but I don't have any cutting lube. Go ahead with the lube pictures.
Drill Press Empty
PostSubject: Re: Drill Press   Drill Press Icon_minitimeTue Jun 08, 2010 5:01 am
I take it you need a domestic drill press?
Drill Press Empty
PostSubject: Re: Drill Press   Drill Press Icon_minitimeTue Jun 08, 2010 6:02 am
It's that or just create a whole new section called non-denominational garage
Drill Press Empty
PostSubject: Re: Drill Press   Drill Press Icon_minitimeTue Jun 08, 2010 8:49 am
I got one you can use. It's in Brodhead Very Happy
Drill Press Empty
PostSubject: Re: Drill Press   Drill Press Icon_minitimeTue Jun 08, 2010 12:25 pm
i have one, in cross plains, lemme know
Drill Press Empty
PostSubject: Re: Drill Press   Drill Press Icon_minitimeTue Jun 08, 2010 3:48 pm
i have one peter
Drill Press Empty
PostSubject: Re: Drill Press   Drill Press Icon_minitimeTue Jun 08, 2010 4:01 pm
I know dude, but I know you have a sprog on the way and that might make your life a little more hectic
Drill Press Empty
PostSubject: Re: Drill Press   Drill Press Icon_minitimeTue Jun 08, 2010 4:32 pm
Peter, I have one too. I would have to fix it first, but this is good motivation to do so. The motor pulley isn't installed.
What are you drilling/fixing?
Drill Press Empty
PostSubject: Re: Drill Press   Drill Press Icon_minitimeTue Jun 08, 2010 4:36 pm
I'm drilling out a bolt to create a banjo bolt fitting that will restrict some oil flow to my turbo
Drill Press Empty
PostSubject: Re: Drill Press   Drill Press Icon_minitimeTue Jun 08, 2010 4:38 pm
Why not just weld up the holes in your stock banjo and drill restrictor holes in that? Hell of a lot easier. I have a welder btw. That is how I did mine.
Drill Press Empty
PostSubject: Re: Drill Press   Drill Press Icon_minitimeTue Jun 08, 2010 4:39 pm
Well I don't have a welder or welding skillz, but if that is an offer to help I will bring the drinks
Drill Press Empty
PostSubject: Re: Drill Press   Drill Press Icon_minitimeTue Jun 08, 2010 4:47 pm
Ill send you a PM.
Drill Press Empty
PostSubject: Re: Drill Press   Drill Press Icon_minitimeTue Jun 08, 2010 10:02 pm
if you guys wanna make a night (or day) of it i have the equipment.
Drill Press Empty
Drill Press
