| 8.8 Trivia | |
+7bigbird94 HoosierDaddy 347 LX OJDAJUICEMAN Blown91LX 408 4 Eye XSFTLBS 11 posters |
| Subject: 8.8 Trivia Tue Feb 22, 2011 4:36 am | |
| So I am putting a 8.8 TracLok 31 spline out of a 97 Explorer in the TA. I am planning on rebuilding the factory traclok with extra discs. One of my questions is where would be a good place to get a clutch pack kits for this rearend? I have noticed that the factory location to fill the diff. with fluid is blocked due to my suspension, so is there a aluminum cover that has a fill plug in it? I am planning on going fast this year so I am using Ford parts to get the GM there. |
| Subject: Re: 8.8 Trivia Tue Feb 22, 2011 5:33 am | |
| Subject: Re: 8.8 Trivia Tue Feb 22, 2011 5:35 am | |
| Oh, forgot to ask. C-Clip eliminators? | |
| Subject: Re: 8.8 Trivia Tue Feb 22, 2011 8:20 am | |
| You can get away with only buying ( 1 ) rebuild kit. Just use ( 2 ) of the old clutches when you rebuild it. Make sure you buy some friction modifier, and C Clip elims are you friend! | |
| Subject: Re: 8.8 Trivia Tue Feb 22, 2011 8:33 am | |
| I would start by tossing that stock diff in the trash. Then order a auburn pro and call it a day. | |
| Subject: Re: 8.8 Trivia Tue Feb 22, 2011 10:21 am | |
| a healthy tlok works very well. 1.73 on street tires for the win. and im sure there is some sort of fancy cover. the 8.8 is one thing ford got right. | |
| Subject: Re: 8.8 Trivia Tue Feb 22, 2011 2:03 pm | |
| Id rock a factory T-Loc over an Auburn anyday. I jsut threw my Auburn in the scrap pile when I took it out. | |
| Subject: Re: 8.8 Trivia Tue Feb 22, 2011 2:15 pm | |
| I am not planning on running c-clips eliminators because I have rear disc brakes, they would hold the axle in if shit were to break.
Carbon discs? Would I still want to run a extra one?
If I were to go with an aftermarket unit, I would only run a Detroit locker. I see Yukon is making a Posi that is rebuidable, but I figure I already will have the traclok.
347 LX Legit
| Subject: Re: 8.8 Trivia Tue Feb 22, 2011 4:16 pm | |
| The carbon fiber disks are what come in the 03/04 cobra diffs. I've never heard of anyone running an extra disk with the carbon fiber set up. | |
| Subject: Re: 8.8 Trivia Tue Feb 22, 2011 5:14 pm | |
| - 408 4 Eye wrote:
- Id rock a factory T-Loc over an Auburn anyday. I jsut threw my Auburn in the scrap pile when I took it out.
Pull it out of the pile and give it to me. | |
| Subject: Re: 8.8 Trivia Tue Feb 22, 2011 6:17 pm | |
| - Blown91LX wrote:
Pull it out of the pile and give it to me. Its under about two feet of snow! | |
| Subject: Re: 8.8 Trivia Tue Feb 22, 2011 6:18 pm | |
| - mtperformance wrote:
- I am not planning on running c-clips eliminators because I have rear disc brakes, they would hold the axle in if shit were to break.
Just go with the regular discs! | |
| Subject: Re: 8.8 Trivia Tue Feb 22, 2011 7:52 pm | |
| - 408 4 Eye wrote:
- Blown91LX wrote:
Pull it out of the pile and give it to me. Its under about two feet of snow! you know if you send that back to auburn they will send you a new unit for lile $200. | |
| Subject: Re: 8.8 Trivia Tue Feb 22, 2011 7:54 pm | |
Just go with the regular discs! Why do you say that. |
| Subject: Re: 8.8 Trivia Tue Feb 22, 2011 7:57 pm | |
| i have a detroit true trac , and its tits... maybe you wanna try that. | |
| Subject: Re: 8.8 Trivia Tue Feb 22, 2011 9:09 pm | |
Why do you say that. Because I know for a fact that you can add extra clutches. I would rather have 4 regular clutches per side than 3 carbon fiber ones per side. | |
| Subject: Re: 8.8 Trivia Wed Feb 23, 2011 7:56 pm | |
- I am planning on going fast this year so I am using Ford parts to get the GM there.
LT1s are slow. | |
| Subject: Re: 8.8 Trivia Wed Feb 23, 2011 8:52 pm | |
LT1s are slow. I keep trying to tell you people that. |
| Subject: Re: 8.8 Trivia Wed Feb 23, 2011 8:55 pm | |
| Subject: Re: 8.8 Trivia Wed Feb 23, 2011 9:12 pm | |
| Subject: Re: 8.8 Trivia Wed Feb 23, 2011 9:52 pm | |
| ^^ Should work! I have never done it, but it looks like it will work. | |
347 LX Legit
| Subject: Re: 8.8 Trivia Wed Feb 23, 2011 10:27 pm | |
| Why would you want to use that style yoke over the other one? | |
| Subject: Re: 8.8 Trivia Wed Feb 23, 2011 10:31 pm | |
| my guess it he does not want the 4 bolt flange and wants a bigger u- joint this this combo | |
| Subject: Re: 8.8 Trivia Wed Feb 23, 2011 11:04 pm | |
| I figured the 4 bolt style would be weak and I wasn't sure on how big or strong the rear u-joint would be?
What do you Mustang guys run? |
| Subject: Re: 8.8 Trivia Thu Feb 24, 2011 12:20 am | |
What do you Mustang guys run? The factory one. I have never seen one fail. | |
| Subject: Re: 8.8 Trivia | |
| 8.8 Trivia | |
