 Talon Build
7 posters
Talon Build Empty
PostSubject: Talon Build   Talon Build Icon_minitimeThu May 26, 2011 4:28 am
So im starting fresh on the talon. Im in no hurry to get it done i just want exactly the way i want it this time. I sold the motor, trans, transfer case. and ecu to a kid from the cities. When we dropped the pan we found out the dumbass that wrecked my car also managed to do enough damage to spin a rod bearing on the number 1 cylinder. The kid decided he wanted it all anyways so he would have parts to start his 6 bolt swap on his 2g. As of now im starting to work on the body. i started cleaning out unnessacary things in the engine bay so i can clean it and make it look brand new again. Heres my progress as of the last couple hours, should get farther this afternoon. Im trying to prepare it so i can fix the rust and get her the long deserved respray.
Talon Build 90ed001
Talon Build 90ed002
This is the color and general look im going for.
Talon Build 10171700_20102165211
And these rims
Talon Build P45rflatblack03ep7
Ill post more pics as i get more done.
Talon Build Empty
PostSubject: Re: Talon Build   Talon Build Icon_minitimeThu May 26, 2011 11:44 am
Nice, what do you plan on doing engine wise?
Talon Build Empty
PostSubject: Re: Talon Build   Talon Build Icon_minitimeThu May 26, 2011 12:39 pm
Well i havent fully decided on my direction engine wise, im not going for crazy power by any means. Im thinking for the most part it will be built around a 20g turbo so it wont be anything to crazy.
Talon Build Empty
PostSubject: Re: Talon Build   Talon Build Icon_minitimeThu May 26, 2011 1:52 pm
I wouldnt go with a 20g
dragonov_elite
dragonov_elite
Talon Build Empty
PostSubject: Re: Talon Build   Talon Build Icon_minitimeThu May 26, 2011 2:47 pm
With that kind of build in mind i would run a 6bolt with 90 rods and ross pistons with BSE kit and thats about it for a block. would be able to handle more than enough power for what that turbo is capable of pushing out. IMO 20g kind of suck though. Way better options out now for the price of a 20g.
Talon Build Empty
PostSubject: Re: Talon Build   Talon Build Icon_minitimeThu May 26, 2011 3:03 pm
ok thanks, i just heard alot of good things on the tomei 20g. Do u have another suggestion??
Talon Build Empty
PostSubject: Re: Talon Build   Talon Build Icon_minitimeThu May 26, 2011 3:25 pm
my progress so far today
I have most of the engine bay empty, i know i can remove a few more things emissions wise but im still reading up on it.
Talon Build Talon001-1
I also removed the front bumper support so i can get the smaller one to make room for the fmic
Talon Build Talon002
so this pic shows u how he left the differetial when the dumb fuck drove it. He removed the rear cover until the rear diff over heated and exploded. Im in the process of pulling out the shaft. Does anyone know what i all need to do the 4 bolt conversion
Talon Build Talon003-1
Gonna start working on the rust later today. ill get pics up when i got em
Talon Build Empty
PostSubject: Re: Talon Build   Talon Build Icon_minitimeThu May 26, 2011 4:22 pm
Holy crap, what a mess. Good luck man!
Talon Build Empty
PostSubject: Re: Talon Build   Talon Build Icon_minitimeThu May 26, 2011 5:20 pm
The only thing you need for a 4 bolt is a complete rear end and the cup that go in the hubs. A 1g rod, 2g piston would be a nice combo as well. A e85 evo 3 16g set up would be very nice!
dragonov_elite
dragonov_elite
Talon Build Empty
PostSubject: Re: Talon Build   Talon Build Icon_minitimeThu May 26, 2011 5:45 pm
I would either suggest an E3 16G or a holset hx35 with a BEP bolt on housing.
Talon Build Empty
PostSubject: Re: Talon Build   Talon Build Icon_minitimeThu May 26, 2011 6:30 pm
nice thanks for the suggestions guys
Talon Build Empty
i almost have all the molding off and i definatly got some rust
Talon Build Empty
PostSubject: Re: Talon Build   Talon Build Icon_minitimeThu May 26, 2011 6:54 pm
I know of a parts car with a 4 bolt rear end, 6 bolt block and 1g rods...
Listen to Kp
or if thats not enough start looking at tubular manifolds/external wastegates and everything else that comes with a bigger turbo
Talon Build Empty
PostSubject: Re: Talon Build   Talon Build Icon_minitimeThu May 26, 2011 7:50 pm
how much for this parts car??
Talon Build Empty
PostSubject: Re: Talon Build   Talon Build Icon_minitimeThu May 26, 2011 9:35 pm
heres the start of the body repair, my rust situation isnt to bad but definatly needs attention.
Talon Build 003
Talon Build 005
Talon Build Empty
PostSubject: Re: Talon Build   Talon Build Icon_minitimeThu May 26, 2011 9:57 pm
The owner is myles4g63 on this site.
and my guess is cheap enough to be worth it.
Mr Peepers
Mr Peepers
Talon Build Empty
PostSubject: Re: Talon Build   Talon Build Icon_minitimeThu May 26, 2011 10:02 pm
A stock 6 bolt should be plenty for a 20g or similar. 1g rod 2g piston if you are in there; most expensive part is machining the 1g rods to fit the 2g pistons. My 2g pistons were something like $70 shipped to my door. Or 2g pistons and eagle rods if you can find a good deal; doesn't have to be fancy.
An hy35 would be interesting. It's an open port t3 so there are a ton of cheap manifolds to choose from and it has the same compressor wheel as a 7 blade hx35.
Talon Build Empty
PostSubject: Re: Talon Build   Talon Build Icon_minitimeThu May 26, 2011 10:19 pm
Dsm graveyard makes frenkenstein rods for pretty cheap, they sell the combo for like 350. I was gonna run some 272 cams also.
I will def take ur advice on the turbo set up
Mr Peepers
Mr Peepers
Talon Build Empty
PostSubject: Re: Talon Build   Talon Build Icon_minitimeThu May 26, 2011 10:57 pm
It's something like $100 for a machine shop to machine 1g rods to fit 2g pistons for reference.
Talon Build Empty
PostSubject: Re: Talon Build   Talon Build Icon_minitimeThu May 26, 2011 11:32 pm
i was also reading that going to evo 9 pistons was a good way to go
Mr Peepers
Mr Peepers
Talon Build Empty
PostSubject: Re: Talon Build   Talon Build Icon_minitimeFri May 27, 2011 8:19 pm
Deck height on the evo's are a bit taller or something to that effect so the pistons aren't the same compression ratio as you would expect. Ends up to something around the 2g piston compression ratio(8.5) but with no real quench height. Too expensive for my blood anyway :p
Talon Build Empty
PostSubject: Re: Talon Build   Talon Build Icon_minitimeSat May 28, 2011 2:32 pm
ok thanks for the advice
Talon Build Empty
PostSubject: Re: Talon Build   Talon Build Icon_minitimeSun May 29, 2011 1:33 am
So im still tryin to find a donor car for mine. All i need is a 6 bolt 91 motor preferably, trans and transfer case so i have a cre to ship, 4 bolt rear, and possibly some good rear quaters
Talon Build Empty
Talon Build
» My MR2 build.
» '89 Mr2 Build
» 95 S14 build
» 01 Z06 build
» My build
