 question for the subaru guru's
6 posters
question for the subaru guru's Empty
PostSubject: question for the subaru guru's   question for the subaru guru's Icon_minitimeTue Nov 01, 2011 12:29 pm
my buddy just picked up a 93 legacy sedan with an auto transmission that has no reverse. Im trying to figure out if I can swap in the 5 speed from my 98 impreza. there both 2.2l engines and since he cant afford a different trans for his car im trying to jewcraft something together. And it works out good since my car is blown to fuck anyway. Any imput would be great.
PostSubject: Re: question for the subaru guru's   question for the subaru guru's Icon_minitimeTue Nov 01, 2011 12:38 pm
That should work.
PostSubject: Re: question for the subaru guru's   question for the subaru guru's Icon_minitimeTue Nov 01, 2011 1:06 pm
You want to sell any parts off the wagon? I need a few misc. things!
PostSubject: Re: question for the subaru guru's   question for the subaru guru's Icon_minitimeTue Nov 01, 2011 1:29 pm
sure, what are you looking for?
PostSubject: Re: question for the subaru guru's   question for the subaru guru's Icon_minitimeTue Nov 01, 2011 5:55 pm
I need a blower motor switch! Mine is on high in all the settings.
PostSubject: Re: question for the subaru guru's   question for the subaru guru's Icon_minitimeTue Nov 01, 2011 5:58 pm
Sounds like the blower motor resistor, not the switch.
PostSubject: Re: question for the subaru guru's   question for the subaru guru's Icon_minitimeTue Nov 01, 2011 10:24 pm
Yeah thats gonna be the resistor, and mine works so if you want it we can work something out
PostSubject: Re: question for the subaru guru's   question for the subaru guru's Icon_minitimeTue Nov 01, 2011 10:44 pm
Cool!
PostSubject: Re: question for the subaru guru's   question for the subaru guru's Icon_minitimeTue Nov 01, 2011 11:01 pm
Ill be home this weekend. 6088437981 give me a call or something
PostSubject: Re: question for the subaru guru's   question for the subaru guru's Icon_minitimeTue Nov 01, 2011 11:16 pm
should work most of the subaru bellhousings are the same, not 100 percent sure though
PostSubject: Re: question for the subaru guru's   question for the subaru guru's Icon_minitimeWed Nov 02, 2011 12:17 am
I was doing some research on rs25.com and it looks like the whole driveline shabang needs to be swapped over. Trans, driveshaft rear diff and axles computer plus some wire splicing Sad
PostSubject: Re: question for the subaru guru's   question for the subaru guru's Icon_minitimeWed Nov 02, 2011 6:34 am
That sounds like alot of work!
PostSubject: Re: question for the subaru guru's   question for the subaru guru's Icon_minitimeWed Nov 02, 2011 11:35 am
Yeah man there are going to be some typical auto to manual swap issues you'd have.
If it has ABS there are speed sensors on the auto trans that are part of the ABS system so you will either have to wire something together or not have ABS.
You may or may not be able to use the same speedo cable.
You will have to rewire the neutral start switch, reverse lights and and lockouts that the auto trans has.
You will probably have to get a new drive shaft.
You will need to source a clutch pedal and master cylinder assembly (I assume from your car).
That's just shit you have to do that is non specific to a Subaru, who knows what else you'll find.
PostSubject: Re: question for the subaru guru's   question for the subaru guru's Icon_minitimeWed Nov 02, 2011 4:41 pm
diff ratios wont match so that would need to be swapped too
Sad
PostSubject: Re: question for the subaru guru's   question for the subaru guru's Icon_minitimeWed Nov 02, 2011 6:56 pm
Yikes. Thats a lot of stuff to change, and expensive in the long run I bet
PostSubject: Re: question for the subaru guru's   question for the subaru guru's Icon_minitimeWed Nov 02, 2011 8:17 pm
Just put his engine in your car!
PostSubject: Re: question for the subaru guru's   question for the subaru guru's Icon_minitimeWed Nov 02, 2011 10:19 pm
my shell is beat to shit. Probly just gonna find him an auto
» Subaru question
» Subaru Fail
» "jdm subaru"
» Subaru Shootout
» Subaru Isle of Man TT
