| might need to change wheels on the coronet idea's? | |
+5XSFTLBS 240sxguy bigbird94 Blown91LX MikeyT 9 posters |
| Subject: might need to change wheels on the coronet idea's? Thu Apr 07, 2011 8:25 pm | |
| Hey guys I've learned kind of an unsettling thing on the upgrade to disc brakes. The only way to get them to seat right was to run a spacer on my front. This pushes out my Cragers S/S wheels a bit. Now everyone says it should be fine, but I'm a little concerned with running a unilug wheel set up on something with a spacer, especially if I'm running close to 100 mph at the track often. So I'm asking my esteemed car brothers if they could give me there opinion and give suggestions for rims or to tell me i'm just being paranoid about this issue. I'm looking for a 15 inch rim, no this is not negotiable. Thanks as always Mike | |
| Subject: Re: might need to change wheels on the coronet idea's? Thu Apr 07, 2011 8:28 pm | |
| Subject: Re: might need to change wheels on the coronet idea's? Thu Apr 07, 2011 8:33 pm | |
| Subject: Re: might need to change wheels on the coronet idea's? Thu Apr 07, 2011 8:37 pm | |
| Weld pro stars would look good. | |
| Subject: Re: might need to change wheels on the coronet idea's? Thu Apr 07, 2011 8:49 pm | |
| I never realized how sweet your car was until seeing that pic. | |
| Subject: Re: might need to change wheels on the coronet idea's? Thu Apr 07, 2011 8:55 pm | |
| yeh man that car is amazing , do you have the original rims ? Or will they not work with the disc/uni ? |
| Subject: Re: might need to change wheels on the coronet idea's? Thu Apr 07, 2011 9:04 pm | |
| Are those the wheels with the elongated holes that use a goofy washer to match the bolt pattern of the car? Are your wheels hubcentric? How thick of a spacer? | |
| Subject: Re: might need to change wheels on the coronet idea's? Thu Apr 07, 2011 9:37 pm | |
| Cragar classics come in a bunch of different offsets that may work for you. They would still fit the overall "theme" of your vehicle. | |
| Subject: Re: might need to change wheels on the coronet idea's? Thu Apr 07, 2011 9:59 pm | |
| Subject: Re: might need to change wheels on the coronet idea's? Thu Apr 07, 2011 10:03 pm | |
| - nightrunner06 wrote:
- 24" giovanni s
Winar! jk get some stock looking ones IMO, just curious any reason to the 15" only? | |
| Subject: Re: might need to change wheels on the coronet idea's? Thu Apr 07, 2011 10:53 pm | |
| Subject: Re: might need to change wheels on the coronet idea's? Thu Apr 07, 2011 11:28 pm | |
- 24" giovanni s
Only you would suggest something this gay! The reason for the 15 inch is because the 14's will no longer fit with the disc brakes. So Steve I can get the Cragers without the uni bolt pattern huh? That might be the way to go, because I really like them. Also, thanks for the compliments on the Coronet. Mike | |
| Subject: Re: might need to change wheels on the coronet idea's? Fri Apr 08, 2011 1:56 am | |
| - Blown91LX wrote:
- Weld pro stars would look good.
+1 |
| Subject: Re: might need to change wheels on the coronet idea's? Fri Apr 08, 2011 3:30 am | |
| Subject: Re: might need to change wheels on the coronet idea's? Fri Apr 08, 2011 8:12 am | |
| I would like to see the wheels from Peters new car on that thing, but that's just me!
Once again, nice car man. I have yet to see it in person! | |
| Subject: Re: might need to change wheels on the coronet idea's? | |
