 4 banger to V6 swap Fiero
fokus83
7 posters
4 banger to V6 swap Fiero Empty
PostSubject: 4 banger to V6 swap Fiero   4 banger to V6 swap Fiero Icon_minitimeTue Jul 05, 2011 8:45 pm
So other then pictures i'll just tell you what i all had to and have to do. First thing first is find a donor 2.8 V6 out of a fiero. After i did that i got the Fiero to my work place, and started disconnect everything and drop the cradle. Ran into a couple problems but everyone who drops a fiero cradle has some sort of problem. After dropping the cradle you then have to take the engine off the cradle, pretty simple have two cradle mounts and the bell housing bolts then its off. Then its time to prep the other motor, you have to take the top plenum off so you can get to the fuel rail to remove the fuel lines. Then because the donor V6 i picked up had an Automatic harness i had to completely strip that off, and replace it with a manual engine harness. Once the engine harness is on, i proceeded to put the V6 fuel lines on and a newer fuel rail. Then you can put the plenum back on. The 4 cylinder and 6 cylinder have different Flywheels so luckily i had a spare laying around. The clutch and pressure plate are the same tho. The transmission spline is relatively short so it makes it a hell of a lot easier to connect the engine.
List of differences between the two
-ECU
-Throttle cable
-coolant hoses
-Flywheel
-Fuel lines
-Fuel pump
-Engine harness
-Engine mounts
-Exhaust
Engine that came out
4 banger to V6 swap Fiero IMG_0307
Donor Engine
4 banger to V6 swap Fiero IMG_0306
Engine stripped down
4 banger to V6 swap Fiero IMG_0313
Automatic Harness and V6 exhaust
4 banger to V6 swap Fiero IMG_0311
Better Fuel rail and injectors
4 banger to V6 swap Fiero IMG_0314
Easier to take off caliper then it is to bled them
4 banger to V6 swap Fiero IMG_0309
Engine cradle being dropped out
4 banger to V6 swap Fiero IMG_0316
Best way to jack up car, use cherry picker and lift on the trunk latch
4 banger to V6 swap Fiero Img_0315
Have to get the cherry picker out of the way some how lol
4 banger to V6 swap Fiero Img_0316
4cyl. off the cradle
4 banger to V6 swap Fiero Img_0317
V6 off the other cradle
4 banger to V6 swap Fiero Img_0318
Good bye Flex plate and hello Flywheel
4 banger to V6 swap Fiero Img_0319
V6 bolted to transmission and cradle
4 banger to V6 swap Fiero Img_0320
Fuel lines and plenum back on
4 banger to V6 swap Fiero Img_0321
It is now already to be put in, started to rain so I figured i would come inside and post this Build
PostSubject: Re: 4 banger to V6 swap Fiero   4 banger to V6 swap Fiero Icon_minitimeTue Jul 05, 2011 9:27 pm
You work fast!
fokus83
fokus83
PostSubject: Re: 4 banger to V6 swap Fiero   4 banger to V6 swap Fiero Icon_minitimeTue Jul 05, 2011 9:31 pm
Should be fun! You should clean that intake and those valve covers up though while it's out!!
fokus83
fokus83
PostSubject: Re: 4 banger to V6 swap Fiero   4 banger to V6 swap Fiero Icon_minitimeTue Jul 05, 2011 9:34 pm
Oh, n/m... just saw your other thread that it's not your car lol
Nice work! Fiero's are cool in their own right.
PostSubject: Re: 4 banger to V6 swap Fiero   4 banger to V6 swap Fiero Icon_minitimeTue Jul 05, 2011 9:51 pm
Wtf. Is this shit!
Jk. Haha. Glad to see something different!
Job well done so far.
PostSubject: Re: 4 banger to V6 swap Fiero   4 banger to V6 swap Fiero Icon_minitimeTue Jul 05, 2011 9:56 pm
do work man
PostSubject: Re: 4 banger to V6 swap Fiero   4 banger to V6 swap Fiero Icon_minitimeTue Jul 05, 2011 10:29 pm
BIG props for doing it outside.
PostSubject: Re: 4 banger to V6 swap Fiero   4 banger to V6 swap Fiero Icon_minitimeTue Jul 05, 2011 10:30 pm
Thanks everyone yeah should be up in running by tomorrow. I'm doing this pretty cheap so thats why i'm trying to go as fast as i can lol, and its my buddy's daily driver Laughing
PostSubject: Re: 4 banger to V6 swap Fiero   4 banger to V6 swap Fiero Icon_minitimeSat Jul 09, 2011 9:22 pm
Just uploaded the video i made, sound quality is pretty bad.
fokus83
fokus83
PostSubject: Re: 4 banger to V6 swap Fiero   4 banger to V6 swap Fiero Icon_minitimeSat Jul 09, 2011 10:54 pm
Oh noes! It has an automatic!!!!! I wouldn't mind having a v-6 fiero sometime but it would have to be a stick. An auto in a mid engine car would be like an rx7 with an auto.
Very nice work and write up though!
PostSubject: Re: 4 banger to V6 swap Fiero   4 banger to V6 swap Fiero Icon_minitimeSat Jul 09, 2011 11:37 pm
I think he said he converted it from a 4 cyl/auto to a 6 cyl/5 speed
PostSubject: Re: 4 banger to V6 swap Fiero   4 banger to V6 swap Fiero Icon_minitimeSat Jul 09, 2011 11:41 pm
This would be correct unless its some high powered engine the fiero needs a 5 speed to even make it worth getting into. When you get to high hp really the only choice is the 4T60-E HD.
PostSubject: Re: 4 banger to V6 swap Fiero   4 banger to V6 swap Fiero Icon_minitimeSat Jul 09, 2011 11:44 pm
I just said that the neutral safety switch was disconnected so i didn't have to push in the clutch. Laughing
fokus83
fokus83
PostSubject: Re: 4 banger to V6 swap Fiero   4 banger to V6 swap Fiero Icon_minitimeMon Jul 11, 2011 9:22 am
Sorry, I missed that. I watched the video and thought I saw that the shifter was an auto.
PostSubject: Re: 4 banger to V6 swap Fiero   4 banger to V6 swap Fiero Icon_minitimeMon Jul 11, 2011 12:31 pm
Lol nope she's a stick.
» Fiero engine swap this winter
» hey Fiero dude
» Silver and blue Fiero...
» Pontiac Fiero GT Now with Authoritah
» Build Thread – The Misadventures of a Cam Swap
