| Hillrod race truck | |
+12OJDAJUICEMAN Disgustang Petes71cam Vanilla Gorilla HoosierDaddy overblown LLcoolJames blown383z28 Tusk Bod89lx mr.johnson Blown91LX 16 posters |
| Subject: Hillrod race truck Sun Sep 18, 2011 9:39 pm | |
| I sold that clapped out foxbody, and picked up a sweet clapped out cummins. Has a cracked block. Needs a bunch of work. Probably wont be done for awhile. Has a few mods already. Edge comp box, 5 inch exhaust, fass 150 lift pump, has a few gauges to keep track of stuff, has a new box of arp head studs in the cab, might have a couple trans mods.
| Subject: Re: Hillrod race truck Sun Sep 18, 2011 10:03 pm | |
| like!!
now madison can hang with jv, | |
| Subject: Re: Hillrod race truck Sun Sep 18, 2011 10:44 pm | |
| Yea you need to get some 8" stacks and some lights and a CB!!!!!!!!!!!!!!!! | |
| Subject: Re: Hillrod race truck Sun Sep 18, 2011 10:47 pm | |
| I expect to see 11s | |
| Subject: Re: Hillrod race truck Mon Sep 19, 2011 7:48 am | |
| ^ 11's are the goal. Wont know what it will do until it runs again. | |
blown383z28 Legit
Posts : 932 Join date : 2010-04-07 Age : 41 Location : Waupun Wi
| Subject: Re: Hillrod race truck Mon Sep 19, 2011 10:05 am | |
| stay away from the 52 blocks... (i think that is the #) | |
| Subject: Re: Hillrod race truck Mon Sep 19, 2011 11:12 am | |
| I have a cb ill cell you for ten bucks. Comes with all the wires and a shorty magnet mount | |
| Subject: Re: Hillrod race truck Mon Sep 19, 2011 11:49 am | |
| Awesome. The block number to stay away from is 53. Especially if its from a 99-02. The earlier ones don't seem to have the same problem. I'd also check to see if the current block is a 53. Although unlikely these days, if that truck happens to have less than 150K on it and it has a cracked 53 block, cummins will replace it under warranty. It'll be interesting to see whats in the tranny. Hopefully at least valve body and a converter. Also the pump already being done is sweet. | |
| Subject: Re: Hillrod race truck Mon Sep 19, 2011 1:19 pm | |
| It is a 53 block. Truck had 173k on it. I have a running engine lined up for pretty cheap. Has 50hp ddp injectors. And is supposed to be a mexican block. The trans has billet shafts, sun coast valvebody, a bd hd rebuild kit, billet tripple disc converter, bd billet flex plate, mag hytech pan, and some ts lockup box. | |
| Subject: Re: Hillrod race truck Mon Sep 19, 2011 1:35 pm | |
| Wanna race? I get 7 and the hit.
Last edited by nightrunner06 on Mon Sep 19, 2011 2:30 pm; edited 1 time in total | |
| Subject: Re: Hillrod race truck Mon Sep 19, 2011 1:41 pm | |
| - nightrunner06 wrote:
- Wanna race? I I get 7 and the hit.
Do it Cory... he's so nervous he's stuttering. |
| Subject: Re: Hillrod race truck Mon Sep 19, 2011 2:29 pm | |
| Subject: Re: Hillrod race truck Mon Sep 19, 2011 2:36 pm | |
| - Blown91LX wrote:
- It is a 53 block. Truck had 173k on it. I have a running engine lined up for pretty cheap. Has 50hp ddp injectors. And is supposed to be a mexican block. The trans has billet shafts, sun coast valvebody, a bd hd rebuild kit, billet tripple disc converter, bd billet flex plate, mag hytech pan, and some ts lockup box.
Damn! If it has all that already you're off the hook for a lot of coin and ready to make some good power. That'll be a great running truck. | |
Vanilla Gorilla Legit
Posts : 283 Join date : 2010-06-01 Age : 34 Location : Janesville Sucka!
| Subject: Re: Hillrod race truck Mon Sep 19, 2011 3:27 pm | |
| Should be fun, what do you plan to do with it? Fun driver or a pull or drag truck? btw 4wd launches are cool feeling with a half ton of torque lol | |
| Subject: Re: Hillrod race truck Mon Sep 19, 2011 3:53 pm | |
| This isnt my first diesel. Im looking for a street/strip truck. | |
| Subject: Re: Hillrod race truck Tue Sep 20, 2011 2:54 pm | |
| Cool, my dad's got an 03 Dmax (got a super good deal so it's not a cummins) with Edge Juice with Attitude, Impressive I have to admit. I'm in the market for a 1st gen cummins, less power and potential but it'd do what I'd need to and I like that body style most lol all old and boxy. Good luck with the build. | |
| Subject: Re: Hillrod race truck Thu Nov 24, 2011 8:49 pm | |
| The engine is out and at Fullboar. Things are happening. | |
| Subject: Re: Hillrod race truck Tue Dec 06, 2011 12:20 am | |
| Both engines are now apart. Both were in really good shape. The engine that was in the truck looked like new inside. And the block was not cracked. It has a small notch on the edge of the number 5 hole. Has to be a factory flaw. Been there since day one. I will still be using the non 53 block anyhow. Going to be starting the head work soon. Milling the intake off for porting. Then building a sheet metal intake to replace the stock pos. Engine wont be done for awhile. I have to wait until I get my cometic gaskets before I can finish it . They should be ready in the spring. I will be testing cometic's new head gasket for them. I have a long way to go. But have a decent start. | |
| Subject: Re: Hillrod race truck Tue Dec 06, 2011 12:31 am | |
| Sounds like you got a good start on it. Is this gonna be done by spring? | |
| Subject: Re: Hillrod race truck Tue Dec 06, 2011 2:31 am | |
| Awesome man. Should be a brawler when it's done it sounds like. | |
| Subject: Re: Hillrod race truck Tue Dec 06, 2011 9:46 am | |
| - petes71cam wrote:
- Sounds like you got a good start on it. Is this gonna be done by spring?
I kinda doubt it. I will be running out of free time soon. Then I will only have a few hours a week to work on it. I am just going to take my time and do it right. | |
| Subject: Re: Hillrod race truck Tue Dec 06, 2011 3:17 pm | |
| Sounds like monster in the making. | |
| Subject: Re: Hillrod race truck Tue Dec 06, 2011 3:23 pm | |
| at least you will have something with more than 273whp now | |
| Subject: Re: Hillrod race truck Tue Dec 06, 2011 10:15 pm | |
| Subject: Re: Hillrod race truck Wed Dec 21, 2011 10:09 am | |
| Picked up most of the p-pump swap. That should spice things up a bit. | |
| Subject: Re: Hillrod race truck | |
