 1994 Camaro Z28 official build thread
turbocripple
blown383z28
24 posters
Go to page : 1, 2, 3, 4, 5  Next
1994 Camaro Z28 official build thread Empty
PostSubject: 1994 Camaro Z28 official build thread   1994 Camaro Z28 official build thread Icon_minitimeWed Jul 11, 2012 8:01 pm
Its time I finally post an official build thread for my Camaro.
All of you know, this used to be Chris's car, I bought it last April.
1994 Camaro Z28
383 Stroker
Automatic transmission
Full exhaust
Last fall, while driving at 55 MPH to work one evening, the crank snapped right in front of the first main:
1994 Camaro Z28 official build thread Photobucket-8031-1330202351283
1994 Camaro Z28 official build thread Photobucket-16263-1330202331524
This was likely due to the wrong flexplate for the application, as well as it being a crappy cast eagle stroker crank.
Also, during tear down, we found out that the car had been overheated at one point trashing a bunch of stuff:
1994 Camaro Z28 official build thread Photobucket-7167-1330202099827
1994 Camaro Z28 official build thread Photobucket-48637-1330202249778
SO, the car basically needed an entire reciprocating assembly, as well as a bunch of machine work.
Mahle .30 over forged pistons:
1994 Camaro Z28 official build thread 14_imagejpeg952
Eagle forged H-Beam rods:
1994 Camaro Z28 official build thread 6_imagejpeg952
Eagle 4340 Forged Crank with the snout keyed:
1994 Camaro Z28 official build thread 17_imagejpeg952
New bearings, rings, ect... One piece Trickflow Pushrods and cleaned up lifters. We also kept the GM847 camshaft and the Melling High Volume Oil pump.
1994 Camaro Z28 official build thread 11_imagejpeg952
The mains were splayed to a 4 bolt:
1994 Camaro Z28 official build thread 12_imagejpeg952
Also, some Machine work was needed to fit the larger rods:
1994 Camaro Z28 official build thread 16_imagejpeg952
PostSubject: Re: 1994 Camaro Z28 official build thread   1994 Camaro Z28 official build thread Icon_minitimeWed Jul 11, 2012 8:09 pm
Next, was assembly of the short block:
1994 Camaro Z28 official build thread 15_imagejpeg952
1994 Camaro Z28 official build thread 5_imagejpeg952
1994 Camaro Z28 official build thread 2_imagejpeg952
The heads were gone through, higher rate springs were installed along with a SINGLE exhaust valve that was bent. Also, a 5 angle vlave job was performed, along with some port work here and there.
ARP head studs:
On the engine:
1994 Camaro Z28 official build thread 2012-05-08_22-27-10_681
A new timing chain and water pump drive were installed, as well as multiple little parts. There was also a new windage tray (moroso) installed to match the oil pan better:
Dave even went the extra mile and fabricated an EGR blockoff plate:
1994 Camaro Z28 official build thread 19_imagejpeg952
1994 Camaro Z28 official build thread 20_imagejpeg952
Complete Motor:
1994 Camaro Z28 official build thread 3_imagejpeg952
The motor is now in the car, and I'm just waiting on transmission parts and a tune. The car also has been converted to OVC wires, a vented Optispark setup, and now has ES poly motor mounts. Also, all hardware in the bottom end is now ARP2000 stuff, along with a bunch of other ARP bolts (timing cover, water pump, intake, Flexplate to engine, ect.
Trans is going through a rebuild at the moment, with Raybestos Red Devil Clutches, a new pump, and a PTC 3600 street/strip stall converter. Also added was a TCI SFI approved balanced flex plate. I need to get a different harmonic dampener at some point, as well as a couple of other parts here and there. The 18' chrome wheels will be gone, swapped for a set of 17' 2002 SS wheels. Eventually I will be running Nitto 555R drag radials. The pacesetter long tubes were put back on the car, along with teh same exhaust the car had when I bought it. Also, we fixed a bunch of small issues, like the temp sender for the coolant gauge, the battery cables, the ground straps, and the oil pressure sending unit. next on the list is a Strange 12 bolt rear end.
PostSubject: Re: 1994 Camaro Z28 official build thread   1994 Camaro Z28 official build thread Icon_minitimeWed Jul 11, 2012 10:10 pm
Not sure what a Strange 60 is gonna set you back, but check into Quick performance. I'm going with a 9 inch for the 02. A complete bolt in housing with 35 spline moser axles to my door is 1200 bucks. I'm going 35 spline because that whats in the 71, this way the center sections interchange. Then I'm going to Ebay to get the complete center section with gear of my choice with a detroit locker. There is a guy on there that sells center sections from a Nascar team that have only been raced once. These are real quality with no expense spared. (I know this because a couple buddies of mine bought them.) I figured after all is done I'd have less than 2 grand for a complete bolt in rearend. But anyway I thought I'd throw this out there and try to save you a few bucks.
PostSubject: Re: 1994 Camaro Z28 official build thread   1994 Camaro Z28 official build thread Icon_minitimeWed Jul 11, 2012 10:15 pm
It looks like dave took the time to do things right.
best of luck to yah.
PostSubject: Re: 1994 Camaro Z28 official build thread   1994 Camaro Z28 official build thread Icon_minitimeWed Jul 11, 2012 10:38 pm
And for your opti spark blues. Seen this on another site
http://www.eficonnection.com/eficonnection/default.aspx
blown383z28
blown383z28
PostSubject: Re: 1994 Camaro Z28 official build thread   1994 Camaro Z28 official build thread Icon_minitimeThu Jul 12, 2012 6:09 am
please tell me you got a bigger throttle body for that thing... scratch
PostSubject: Re: 1994 Camaro Z28 official build thread   1994 Camaro Z28 official build thread Icon_minitimeThu Jul 12, 2012 6:24 am
Hmmm. nope. I didn't think it was a restriction until much more power than I'll be making. Was I wrong?
The intake is opened up enough for a 58mm TB if I need one.
blown383z28
blown383z28
PostSubject: Re: 1994 Camaro Z28 official build thread   1994 Camaro Z28 official build thread Icon_minitimeThu Jul 12, 2012 6:38 am
Yes buy one.... even a used one...
blown383z28
blown383z28
PostSubject: Re: 1994 Camaro Z28 official build thread   1994 Camaro Z28 official build thread Icon_minitimeThu Jul 12, 2012 6:39 am
At least b4 u tune it!
PostSubject: Re: 1994 Camaro Z28 official build thread   1994 Camaro Z28 official build thread Icon_minitimeThu Jul 12, 2012 9:51 pm
motor looks nice! like how ya did everything right. thats what its like goin with dave tho.
PostSubject: Re: 1994 Camaro Z28 official build thread   1994 Camaro Z28 official build thread Icon_minitimeMon Jul 16, 2012 11:42 pm
Transmission is now completely rebuilt and ready to rock. I pick it up tomorrow. I also have to call the tuner up to schedule an appointment. Hopefully that doesn't take too long.
PostSubject: Re: 1994 Camaro Z28 official build thread   1994 Camaro Z28 official build thread Icon_minitimeTue Jul 17, 2012 8:49 pm
looking good man. hopefully you can get it out there soon to start earning some respect. for some thats more important. Boom! fast and the furious quote of the day.
PostSubject: Re: 1994 Camaro Z28 official build thread   1994 Camaro Z28 official build thread Icon_minitimeTue Jul 17, 2012 11:27 pm
LOL!
Thanks!
PostSubject: Re: 1994 Camaro Z28 official build thread   1994 Camaro Z28 official build thread Icon_minitimeThu Jul 19, 2012 9:54 pm
Car is back on the road! Feels much stronger than it did before. The transmission works great, and I have to say.... I'm loving the PTC stall so far! The car goes in for the tune the week of the first. Better late than never!
PostSubject: Re: 1994 Camaro Z28 official build thread   1994 Camaro Z28 official build thread Icon_minitimeThu Jul 19, 2012 10:14 pm
I'll race you from a dig only.
PostSubject: Re: 1994 Camaro Z28 official build thread   1994 Camaro Z28 official build thread Icon_minitimeThu Jul 19, 2012 10:43 pm
Tye gets his race first! After that, sure! *waves goodbye to tires*
*edit*
New plates on the car:
1994 Camaro Z28 official build thread 2012-07-20_02-20-53_542
PostSubject: Re: 1994 Camaro Z28 official build thread   1994 Camaro Z28 official build thread Icon_minitimeFri Jul 20, 2012 6:58 am
Excessive fat pounds? Smile
PostSubject: Re: 1994 Camaro Z28 official build thread   1994 Camaro Z28 official build thread Icon_minitimeFri Jul 20, 2012 7:18 am
LOL Dick! ^
Torque.... you remember what that is, right? Smile
PostSubject: Re: 1994 Camaro Z28 official build thread   1994 Camaro Z28 official build thread Icon_minitimeFri Jul 20, 2012 8:48 am
LOL Dick! ^
No, I don't...... maybe someday again.
PostSubject: Re: 1994 Camaro Z28 official build thread   1994 Camaro Z28 official build thread Icon_minitimeFri Jul 20, 2012 8:51 am
That plate is kinda gay on that car Kevin. I win for the most torques.
PostSubject: Re: 1994 Camaro Z28 official build thread   1994 Camaro Z28 official build thread Icon_minitimeFri Jul 20, 2012 8:55 am
OH Yeah!!!??? How much torque does your smoke blower make???
PostSubject: Re: 1994 Camaro Z28 official build thread   1994 Camaro Z28 official build thread Icon_minitimeFri Jul 20, 2012 10:04 am
Thousands.
PostSubject: Re: 1994 Camaro Z28 official build thread   1994 Camaro Z28 official build thread Icon_minitimeFri Jul 20, 2012 10:08 am
^ hhmmmm....sweet! I'm thinking we need to line em up!!!???
PostSubject: Re: 1994 Camaro Z28 official build thread   1994 Camaro Z28 official build thread Icon_minitimeFri Jul 20, 2012 10:45 am
My 7200lb tow pig against your 3000lb jizz rocket? I will just give you the win.
PostSubject: Re: 1994 Camaro Z28 official build thread   1994 Camaro Z28 official build thread Icon_minitimeFri Jul 20, 2012 2:03 pm
I'm your huckleberry blackout. Tonight?
Page 1 of 5Go to page : 1, 2, 3, 4, 5  Next
» 2010 Camaro build
» STiedVR4Guy's VR-4 Build Thread
» Build Thread suggestions.
» My built/build thread 95' 240sx
» STiedVR4Guy's STi Build thread
