| 2010 ITR build thread!! UPDATE 2.25.11 | |
+21Ryan97 ma70tt HoosierDaddy Overboosting Blinker Fluid? nasty187 myles4g63 MikeyT WWevoX Tusk OJDAJUICEMAN Mclovin23 Disgustang LLcoolJames bigbird94 mr.johnson 2jz-U-Ltr 408 4 Eye cletus Fuckin Schiller!! JDMasfck 25 posters |
JDMasfck Legit
Posts : 964 Join date : 2010-05-13
| Subject: 2010 ITR build thread!! UPDATE 2.25.11 Mon Oct 18, 2010 10:23 am | |
| Subject: Re: 2010 ITR build thread!! UPDATE 2.25.11 Mon Oct 18, 2010 10:42 am | |
| what are you doing to it? and same question goes for David's EK haha | |
JDMasfck Legit
| Subject: Re: 2010 ITR build thread!! UPDATE 2.25.11 Mon Oct 18, 2010 10:45 am | |
| I'm doing a full rebuild on the ENTIRE car.. every thing's getting powder coated/painted, all new gaskets, bolts, hardware ect.. I'm also shaving the bay...
As far as David's you'll have to ask him.. he has some good plans also!!
Ariel, I'ma need your welding skills on my o2 neck to block off the heater hose outlet.
cletus Legit
Posts : 533 Join date : 2010-01-26 Age : 42 Location : De Forest
| Subject: Re: 2010 ITR build thread!! UPDATE 2.25.11 Mon Oct 18, 2010 12:00 pm | |
| sure just LMK mang I'm not hard to find | |
JDMasfck Legit
| Subject: Re: 2010 ITR build thread!! UPDATE 2.25.11 Mon Oct 18, 2010 12:03 pm | |
| haha.. Yeah.. I'll hit you up in a week or so.. | |
JDMasfck Legit
| Subject: Re: 2010 ITR build thread!! UPDATE 2.25.11 Sun Oct 24, 2010 9:51 am | |
| Subject: Re: 2010 ITR build thread!! UPDATE 2.25.11 Sun Oct 24, 2010 10:19 am | |
| Hope you have a good heater! Your gonna be hibernating in that barn. | |
JDMasfck Legit
| Subject: Re: 2010 ITR build thread!! UPDATE 2.25.11 Sun Oct 24, 2010 11:31 am | |
| it's fully insulated..and I have a big barrel stove and about 6 cord of wood..i'll be good!..lol | |
| Subject: Re: 2010 ITR build thread!! UPDATE 2.25.11 Sun Oct 24, 2010 11:48 am | |
| I'm totally jealous of that work space. Awesome progress man | |
| Subject: Re: 2010 ITR build thread!! UPDATE 2.25.11 Sun Oct 24, 2010 1:27 pm | |
i have some from the hatch when it didnt have watercooled nonsense. | |
| Subject: Re: 2010 ITR build thread!! UPDATE 2.25.11 Sun Oct 24, 2010 4:23 pm | |
| Very nice, keep up the good work. | |
JDMasfck Legit
| Subject: Re: 2010 ITR build thread!! UPDATE 2.25.11 Sun Oct 24, 2010 6:24 pm | |
| - mr.johnson wrote:
i have some from the hatch when it didnt have watercooled nonsense. Sweet.. So does that mean you have one with the plate on it? if so what do you want for it.... | |
| Subject: Re: 2010 ITR build thread!! UPDATE 2.25.11 Sun Oct 24, 2010 7:17 pm | |
| no just the ones on the head and the back of the block,
JDMasfck Legit
| Subject: Re: 2010 ITR build thread!! UPDATE 2.25.11 Sun Oct 31, 2010 8:48 pm | |
| Well I met up with Ariel, ( thanks bud ) and we are going to work out a brake booster delete plate for my ITR. Since I use to be a AutoCad nut, I thought I'd draw up something to get started till the Willwood Master Cylinder gets in. Pretty basic for now till I can edit it and add the parts for the MC to bolt up on to. | |
JDMasfck Legit
| Subject: Re: 2010 ITR build thread!! UPDATE 2.25.11 Sun Oct 31, 2010 10:12 pm | |
| Little more work, put in correct hole diameter and countersunk. | |
cletus Legit
| Subject: Re: 2010 ITR build thread!! UPDATE 2.25.11 Sun Oct 31, 2010 11:29 pm | |
| nice you can make me blueprint and everything huh???? | |
JDMasfck Legit
| Subject: Re: 2010 ITR build thread!! UPDATE 2.25.11 Mon Nov 01, 2010 10:44 am | |
| Yeah.. I told you I was a cad nut..lol.. I can even convert it to Solidworks if you want. Otherwise I'll just bring you the print that shows all dimensions. LMK what works for you. | |
cletus Legit
| Subject: Re: 2010 ITR build thread!! UPDATE 2.25.11 Mon Nov 01, 2010 11:47 am | |
JDMasfck Legit
| Subject: Re: 2010 ITR build thread!! UPDATE 2.25.11 Mon Nov 01, 2010 12:09 pm | |
| sounds good. I ordered my Willwood Master Cylinder so once that gets in I'll be able to finish it up.
And do you want to take measurements for the Billet VC i'm getting? | |
JDMasfck Legit
| Subject: Re: 2010 ITR build thread!! UPDATE 2.25.11 Mon Nov 15, 2010 12:42 pm | |
| Not much to post.. Lets just say I'm a shitty welder, and I might just pay someone to get it done.. hint hint Ariel..lol Here is my first few welds done and ground down a bit.. As you can see I had to go back and add some more weld in a few places.. More to come. | |
JDMasfck Legit
| Subject: Re: 2010 ITR build thread!! UPDATE 2.25.11 Thu Dec 02, 2010 4:40 pm | |
| Well small update.. I took a break from the bay and started doing other stuff I need done. First was to plug the fitting that went to the engine for the heater. and to weld/plug the h2o neck ( big thanks to Cletus with Boss and Sons for welding that up for me, pic will be up soon) What I'm replacing. Old. New. Then I started redoing parts for my motor. I did the thermostat housing and h2o neck, distributor, ect. Here is the mani. Clean and degreased and recleaned. Then I put a coat of self etching primer on. Then several light coats of high temp paint, then clear. Looks factory new. | |
| Subject: Re: 2010 ITR build thread!! UPDATE 2.25.11 Thu Dec 02, 2010 10:32 pm | |
| Subject: Re: 2010 ITR build thread!! UPDATE 2.25.11 Thu Dec 02, 2010 10:33 pm | |
| Subject: Re: 2010 ITR build thread!! UPDATE 2.25.11 Fri Dec 03, 2010 1:02 am | |
| Looks good...anyone will have to appreciate the time and effort that you took to go look over every detail. See im the same way. I just have a shop. If i did..wheelchair or not i would be out wrenchin on my car right now! Kuddo's man, great job! |
JDMasfck Legit
| Subject: Re: 2010 ITR build thread!! UPDATE 2.25.11 Tue Dec 21, 2010 4:46 pm | |
| Thanks.. Small update for the fellas who care.. lol UPDATE ON MY CURRENT PROGRESS: I got my carpet in.. I'm going back to my OEM JDM Black caRpet. Since I sold my Red Recaros and got some new PIMP Bride Gias Carbon Kevlar seats. I might bring my seats back from my parents when I go see them for our annual Christmas Extravaganza if I can fit them in the car. Only other thing is I got super rare to find Spoon pit crew jacket, and Type-One Hat. It's the one theses guys wear. Type-One Hat. Since I'm still being the anti-welder..lol Started on the trans at work today instead of 'working' Cleaned it all down with brake Clean, then with steal wool then brake clean, then sprayed it down with water acohol mixture and wiped dry. Only took pics of when I just started. Taped up where I didn't want to paint. Then primed it up with self etching primer of course. Here it is after a few coats. Then painted on light coats of paint. I will let it dry for a day or two then go back and clear it all. More to come.. | |
| Subject: Re: 2010 ITR build thread!! UPDATE 2.25.11 | |
