| Subject: Re: Stock Motor 2011 5.0 TT makes 890whp on 91 with 12 psi Thu Mar 08, 2012 11:08 pm | |
| I know you didnt see that coming...... - 2jz-U-Ltr wrote:
- Bod89lx wrote:
- Yea you ae right^^^^. I was not trying to say it was some sort of big deal just pretty cool what they are doing with this motor just like the 2JZ is a great factory motor as well and can make a shit ton of power. Tye yea I was talking about Pauls truck which has stock cams and heads just a few extra cubes it was 500 fwhp stock and through the auto they made 380-400whp so his made about 50-60 whp with the extra cubes or around there.
Damn it, I was just being a douche, I didn't expected you to be reasonable haha. | |
| Subject: Re: Stock Motor 2011 5.0 TT makes 890whp on 91 with 12 psi Thu Mar 08, 2012 11:10 pm | |
| I know I am just waiting for you to get yours done so you can shut my Ford loving mouth up sucka!!!!!!!!! - 2jz-U-Ltr wrote:
- Supras make in the 800's on stock motor all day. They do it with a little 6 cylinder and only one Turbo so what's the big deal?
| - Thunderballs wrote:
- Yes it really is a stock motor on 12 psi.
It is however on a happy dyno. It was tuned at 5500' and they used a really high correction factor.
Being that f/i cars loose less at altitude than n/a cars the dyno read ~10% high. I am pretty sure you meant turbo instead of f/i but you are absolutely correct. Correction factors are not to be used on turbo cars for accurate numbers. | |
| Subject: Re: Stock Motor 2011 5.0 TT makes 890whp on 91 with 12 psi Thu Mar 08, 2012 11:15 pm | |
Being that f/i cars loose less at altitude than n/a cars the dyno read ~10% high. I am pretty sure you meant turbo instead of f/i but you are absolutely correct. Correction factors are not to be used on turbo cars for accurate numbers. No he ment f/i as in forced induction; nitrous, turbos, blowers....... My comment on not a stock motor was pertaining to the video of the car. | |
| Subject: Re: Stock Motor 2011 5.0 TT makes 890whp on 91 with 12 psi Thu Mar 08, 2012 11:17 pm | |
My comment on not a stock motor was pertaining to the video of the car. Thanks for the correction, when I see F/I fuel injection comes to mind. | |
| Subject: Re: Stock Motor 2011 5.0 TT makes 890whp on 91 with 12 psi | |
